12-01-2021, 11:50 AM
12-01-2021, 03:00 PM
Can you show us a screenshot?
12-01-2021, 07:43 PM
Hello KeithB
Many thanks for your response.
In my main post I have included a "gif" in which the problem can be seen. Since this might not be displayed correctly, I added a picture here:
https://i.ibb.co/16jbvvz/HP-Prime.png
12-01-2021, 08:19 PM
In what sense would this be fatal?
Okay, the parentheses got moved. But that did't break the value or the consecutive calculation, did it?
I don't see anything going fatally wrong here.
12-01-2021, 08:44 PM
Hello Stephan P.
Thank you, too, for your answer.
It really doesn't look too bad at first look. But the position of the parentheses is important.
Let me show you:
Let me show you:
12-01-2021, 09:20 PM
It seems the "Intelligent Math" option isn't very intelligent. :-)
The strange thing is that with "Entry: Algebraic", Textbook Display: [ ]", "Intelligent Math: [x]":
(10^(1/4))^3 => 10^(1/4)^3
which is incorrect, but with "Textbook Display: [x]" it gets displayed as:
\(\left(10^\frac{1}{4}\right)^3 => \left(10^\frac{1}{4}\right)^3\)
which doesn't match the incorrect non-textbook display, even though the incorrect non-textbook display is what gets copied when selected.
12-02-2021, 07:03 AM
(12-01-2021 08:44 PM)Lakeboard Wrote: [ -> ]Let me show you:
Ah, my bad. I overlooked the exponent 1/64. Probably a bit fuzzy in the early morning, I was.
I cannot reproduce this on my Prime, though.
Which firmware version are you using and particularly what settings do you use in Settings page 1 and 2?
12-02-2021, 07:16 AM
Ah, got it.
It's the option Intelligent Math on Settings page 2.
(I've not used this before)
Well, that's definitely something the team wil have to look into.
12-02-2021, 02:21 PM
Many thanks for your help. Especially for checking @ ijabbott and Stephan.
Apparently, it is really a software bug.
So what can we do to report this issue and receive a new firmware update?
I tried to contact my local HP office. But they didn't respond.
12-02-2021, 03:49 PM
I've reported the issue with the product manager.
As to the release of a solution it's wait and see.
12-03-2021, 06:00 PM
Thank you, Stephan, for reporting. That’s really great!
Let's hope that there will be a new firmware soon and that the problem will be resolved.
Stephan, I may have discovered another little thing.
In CAS mode, if the imaginary number is a floating point, the angle is output as radians.
Can you also report this? Unless it is intended. But it doesn't seem that to me.
Here is a picture:
Here is a picture:
12-04-2021, 04:53 PM
That arg() bug seems to be in the Giac/Xcas code, so one for Bernard Parisse to look at.
Here is a giac session running in a Linux terminal. The angle_radian variable seems to have changed from 0 to 1 by itself after
arg(5+6.001i)
arg(5+6.001i)
// Using locale /usr/share/locale/
// en_GB.utf8
// /usr/share/locale/
// giac
// UTF-8
// Maximum number of parallel threads 4
Added 26 synonyms
Welcome to giac readline interface, version 1.7.0
(c) 2001,2021 B. Parisse & others
Homepage http://www-fourier.ujf-grenoble.fr/~parisse/giac.html
Released under the GPL license 3.0 or above
See http://www.gnu.org for license details
May contain BSD licensed software parts (lapack, atlas, tinymt)
Press CTRL and D simultaneously to finish session
Type ?commandname for help
0>> angle_radian:=0
0
// Time 0.01
>> arg(5+6.001i)
50.6594818402
// Time 0
>> angle_radian
1
// Time 0
>> arg(5+6.1i)
0.884174755465
// Time 0
12-06-2021, 08:20 AM
(12-02-2021 02:21 PM)Lakeboard Wrote: [ -> ]Many thanks for your help. Especially for checking @ ijabbott and Stephan.Thank you for noticing. We will add it to the bug tracker and work on a solution asap!
12-06-2021, 11:28 AM
There is indeed a bug, now fixed in giac source, thanks!
12-06-2021, 07:30 PM
Many thanks to KlaasKuperus and parisse.
It is incredibly nice that such bugs are fixed and that the product is actively developed and supported.
It's a great service to the community.
Thank you very much! =)
Together for a great product.
Also thanks to ijabbott for specifying the complex number problem.
