Today with connectivity kit i check for un update and there is message that is available new version
20211126.zip
but if I try to download it fails with this message
"could not read 1464 bytes from compressed file"
Anyone knows why??
Thanks
PS
My connectivity kit is build 2.1.14592 (2021 6 9)
my G2 version is 2.1.14588 (2021 05 05) Hw version D cas version1.5.0 operating system V2.060.650
Something's probably wrong with the file or the server where the Connectivity Kit downloads it from (which is probably not the FTP server), and the Kit errors out.
If you download the update from the FTP site, ftp://ftp.hp.com/pub/calculators/Prime/, and then extract the HPPrime_OS.img file to "HP Connectivity Kit/Firmware/PrimeG2" (or "/PrimeG1" for a G1, I suppose). The Connectivity Kit will find the file and ask if you want to update.
Of course, that might not be the brightest idea...there is no release info for 20211126 as far as I can tell. Maybe a Royal/Moravia employee's got some info?
(11-27-2021 11:16 PM)Liam Hays Wrote: [ -> ]Something's probably wrong with the file or the server where the Connectivity Kit downloads it from (which is probably not the FTP server), and the Kit errors out.
I got it from the ftp site. It seems to work OK. There's no changelog that I can find, though.
Thanks for the heads-up! I had a question about using Cartesian coordinates with Python and the help file answered my questions.
Opening the Connectivity Kit this morning I saw the message about an update being available. Downloading the firmware files for G1 and G2, I also saw the message about "Could not read 1464 bytes from compressed file".
I updated a G1 calculator first. I was disappointed to discover that the WAIT(-1) bug on G1 calculators is still present, this is a serious bug that I have demonstrated here in the past.
Also noticed that after updating a G1 calculator, re-connecting to Connectivity kit again prompts for update. Essentially every time you connect the calculator there will be the update dialog popping up. Whatever test is being done to determine whether a newer version is available in the firmware folders, it fails.
On a G2 calculator running the 2021 05 05 firmware, there was no prompt to update and in fact when selecting the "Update firmware" option from the right-click menu results in a message that there is no update available. Checking further into it, there are no firmware files in the PrimeG2 folder. This is evidently the corrupted file that was not decompressed, ie the 1464 bytes.
To state the obvious, this is not a good look and a little bit of testing would have discovered these update problems for both G1 and G2. This 'update' IMHO should be removed until the obvious problems are corrected.
(11-28-2021 12:47 AM)toml_12953 Wrote: [ -> ]I got it from the ftp site. It seems to work OK. There's no changelog that I can find, though.
@Tom - When you manually download the G2 f/w .zip from the ftp site, which files in the .zip need to be copied to the ...Documents\HP Connectivity Kit\Firmware\PrimeG2 folder?
Mine is empty. apparently cleaned when the new one started to install but then failed extracting, so there's no clue which files are/are not needed. I presume all the odd svn folders are not needed, but am not sure about the .xml file, etc.
(11-29-2021 03:07 PM)rprosperi Wrote: [ -> ] (11-28-2021 12:47 AM)toml_12953 Wrote: [ -> ]I got it from the ftp site. It seems to work OK. There's no changelog that I can find, though.
Here's a list of what's in the ZIP file. You need to copy HPPrime_OS.img and version_-1-2 file to the CK download directory.
The name of the version file is incorrect. Should probably be named "version_20211126"
Product marketing manager?
I have trouble accessing the ftp site. I only found the October update
at "hpcalc.org".
Will the updated file(s) be available at "hpcalc.org"?
Thanks
(11-29-2021 07:40 PM)Liamtoh Resu Wrote: [ -> ]I have trouble accessing the ftp site.
Best use a dedicated FTP app, such as WinSCP
- Address: 'ftp.hp.com'
- port: 21
- username: anonymous
- no password
(11-29-2021 07:40 PM)Liamtoh Resu Wrote: [ -> ]I have trouble accessing the ftp site. I only found the October update
at "hpcalc.org".
Thanks
Try using the (Windows-) Explorer, entering
http://ftp.hp.com
in the address line, or direct
http://ftp.hp.com/pub/calculators/Prime/.
(11-29-2021 08:43 PM)Thomas_Sch Wrote: [ -> ] (11-29-2021 07:40 PM)Liamtoh Resu Wrote: [ -> ]I have trouble accessing the ftp site. I only found the October update
at "hpcalc.org".
Thanks
Try using the (Windows-) Explorer, entering http://ftp.hp.com
Those URLs don't work (at least not with the http:// in front, but it's possible this site's rather broken forum software is adding that). Also, HP's FTP site doesn't work if you try to connect with common FTP software like Filezilla.
I was only able to connect and download by using the Linux command line ftp program. Connect to ftp dot hp dot com on port 21 with anonymous as the username and your email address as the password, run pass to switch to passive mode, cd to /pub/calculators/Prime, run binary to switch to binary mode, and run get with the filename of the desired file (run ls for a directory listing).
I will probably add it to my site soon, but I am a bit miffed that the new developers never sent it to me (or even contacted me about it) like Cyrille/Tim used to. With the problems some above have had I am not sure if I should even post it yet anyway, in case there are issues that should be resolved before a general release.
Under Windows, try in File Explorer.
(11-29-2021 10:11 PM)Cristóbal De Jesús Wrote: [ -> ]ftp://ftp.hp.com/pub/calculators/Prime/
It doesn't work in Win 11 File Explorer but the free FileZilla does.
https://filezilla-project.org/
(11-29-2021 03:17 PM)toml_12953 Wrote: [ -> ] (11-29-2021 03:07 PM)rprosperi Wrote: [ -> ]@Tom - When you manually download the G2 f/w .zip from the ftp site, which files in the .zip need to be copied to the ...Documents\HP Connectivity Kit\Firmware\PrimeG2 folder?
Thanks Tom, I suspected as much but wasn't sure.
Also, note that in the ...Documents\HP Connectivity Kit\Firmware\PrimeG1 folder, populated by the automatic download process (which was OK for G1 and failed for G2), both of these files are present, with a date-stamp of the install time:
version_-1-2 : 3 bytes, <SP> <CR> <LF> or 0x20, 0x0D, 0x0A
version_20211126 : 0 bytes
along with the other G1 update files.
Truth is, I think I'll wait for HP to fix the G2 package. With no release notes, and the ugly bumps of this release so far, I'll let other more intrepid folks with time on their hands do the serious spelunking needed here.
Thanks!
Thank you for the head's up. I too will wait.
(11-29-2021 09:34 PM)Eric Rechlin Wrote: [ -> ] (11-29-2021 08:43 PM)Thomas_Sch Wrote: [ -> ]Try using the (Windows-) Explorer, entering http://ftp.hp.com
You are correct, the forum software added "http:" . Please remove the http:, I forgot to do a Preview.
With Windows10 this worked in explorer, also with Filezilla. I tested both.
But it is indeed astonishing, that the version file has a wrong name, and a descriptive mail is missing here, very uncommon.
If one of the new companies around HP is involved, then that would be awkward.
(11-30-2021 07:41 AM)Thomas_Sch Wrote: [ -> ]If one of the new companies around HP is involved, then that would be awkward.
Yes, it would. But it isn't.
We are currently working on a firmware update indeed, which will be released shortly and will be including release notes for everyone to download and install. See this as an intermediate step that shouldn't have been published. Our apologies for this inconvenience and misunderstanding. Please be a little more patient.
(11-30-2021 01:00 PM)KlaasKuperus Wrote: [ -> ] (11-30-2021 07:41 AM)Thomas_Sch Wrote: [ -> ]If one of the new companies around HP is involved, then that would be awkward.
Thank you for the clarification, Klaas. I will wait until the next update.
