Full Version: HP-41 RPN program solution sought - test problem
What's the best (shortest meant here) way you can devise to program a solution to this problem in HP-41 RPN?
Enter an angle in degrees mode and press A to return the answer.
So start with LBL A and evaluate:
Equation T = ...
What can you come up with ?
Gene
I hope this is not completely stupid, but I'll try (without testing):
lbl A
xeq deg
sto 01
sqrt
1
sto 02
sin
2,5
sto 03
pi
rcl 02
cos
rcl 01
sin
rcl 03
Assuming angle mode is DEG:
 01 LBL A
 02 SIN
 03 LASTX
 04 SQRT
 05 1
 06 +
 07 TAN
 08 *
 09 5
 10 *
 11 1/X
 12 ST+ X
 13 PI
 14 1/X
 15 +
 16 END
I can shave off one byte:
 01 LBL A
 02 SIN
 03 LASTX
 04 SQRT
 05 1
 06 +
 07 TAN
 08 *
 09 .4
 10 X<>Y
 11 /
 12 PI
 13 1/X
 14 +
 15 END
Cheers, Werner
(10-27-2021 08:03 PM)Gene Wrote: [ -> ]What's the best (shortest meant here) way you can devise to program a solution to this problem in HP-41 RPN?
Equation T = ...
Gene
First I draw it in my preferred graphical calculator https://www.desmos.com/calculator/pop31xijnj?lang=de
And in the time I was drawing (took 5min), smarter ones has give to you some solutions.
I was not quick enough ;-)
Great job Werner!
I was curious and comparing it to an algebraic (AOS) version. That was 39 steps/bytes.
(10-28-2021 08:39 AM)floppy Wrote: [ -> ]First I draw it in my preferred graphical calculator https://www.desmos.com/calculator/pop31xijnj?lang=de
Nice plotter, except that it is missing the important fact that x have to be in degrees (not radians nor Bogenmaßen).
(10-29-2021 05:27 PM)Gene Wrote: [ -> ]I was curious and comparing it to an algebraic (AOS) version. That was 39 steps/bytes.
Let's have a try.
Assuming that the complicated function can be simplify as W.Barbosa and Werner have done:
\( f(x)=\frac{\frac{2.5\times sin(\sqrt{x}+1)}{\pi}+\frac{cos(\sqrt{x}+1)}{sin(x)}}{2.5\times sin(\sqrt{x}+1)}=\frac{1}{\pi}+\frac{.4}{sin(x)\times tan(\sqrt{x}+1)} \)
And using a blue TI-57 LCD using certified AOS technology:
STO0 .4 ÷ ( RCL0 sin × ( 1 + RCL0 √x ) tan ) + ∏ 1/x = R/S RST
The last too steps are optional but useful in program; so this function can be recorded using 22 steps (or bytes) in LRN mode.
(10-31-2021 12:58 PM)C.Ret Wrote: [ -> ]And using a blue TI-57 LCD using certified AOS technology:
Perhaps you can save one byte by eliminating the parentheses:
STO0 √x + 1 = tan × RCL0 sin × 2.5 = 1/x + ∏ 1/x = R/S RST
(10-31-2021 05:43 PM)Gerson W. Barbosa Wrote: [ -> ]Perhaps you can save one byte by eliminating the parentheses:
Good suggestion :
STO0 √x + 1 = tan × RCL0 sin ÷ .4 = 1/x + ∏ 1/x = R/S RST (one Werner's step spare here)
STO0 √x + 1 = tan 1/x EXC0 sin STO÷0 .4 STO×0 ∏ 1/x STO+0 RCL0 R/S RST (two more steps spare , but, is this still AOS logic ?)
If it can be keyed on a TI-57 or TI-58C, then we will call it AOS. :-)
Gene
