10-24-2021, 07:06 PM
10-24-2021, 08:08 PM
I was curious and did a little test, and let this counter run for about 10 seconds:
LBL 01
1
GTO 01
a few results:
DM41X slow: ca. 90
DM41X fast: ca. 1100
i41cx on iPad Mini 2: ca. 140
v41 max. Turbo on my PC: ca. 50000
go41cx (Pixel 2XL) x1: ca. 90
go41cx: x8 ca. 1000
go41cx: x32 ca. 6000
go41cx: max ca. 50000
LBL 01
1
GTO 01
a few results:
DM41X slow: ca. 90
go41cx: x8 ca. 1000
10-24-2021, 08:19 PM
This is a bit of an apple (hardware) to orange (software) comparison. FWIW
41CL, Turbo 50: 1,158. Timing subject to finger lag...
10-24-2021, 08:44 PM
Thank you for the feedback, seems the 41CL is actually about 10x faster than i41CX (who’s speed iirc is not hardware dependent actually, ie it runs the same on all iPad / iPhone versions, but I might be wrong there). That is indeed interesting.
Wish I had a PC as it seems the V41 is yet again at least an order of magnitude faster.
Thank you for these numbers!
10-24-2021, 08:47 PM
10-24-2021, 09:41 PM
(10-24-2021 08:44 PM)PeterP Wrote: [ -> ].. i41CX (who’s speed iirc is not hardware dependent actually, ie it runs the same on all iPad / iPhone versions, but I might be wrong there).
it appears to be so, i41cx on an original iPad also counts to about 140 in 10 sec.
2 more values:
py41 (Prime G2) slow: approx. 60
py41 (Prime G2) fast: approx. 300
10-24-2021, 09:52 PM
Here are some numbers using ...
First, the usual speed test :-) is LBL 01 + GTO 01 with the stack containing ones and a zero in X.
Second, here are my results:
i41CX+ in fast mode (iPhone 11) : 3705 counts in a minute.
DM-41X in fast mode (on battery): 12,895 counts in one minute. <-----------
DM-41X in fast mode (on USB): 40,301 counts in one minute. <-------------
Standard HP-41C (from PPC Journal issue where HP-41C was introduced), same program: 1041 counts in a minute.
