If you have an HP 300S and wouldn't mind doing this test
http://www.rskey.org/~mwsebastian/miscprj/results.htm and posting your results here then I say thank you.
It's a one liner in degrees mode:
arcsin (arccos (arctan (tan (cos (sin (9) ) ) ) ) )
In an earlier thread Stefan (haven't seen him in a while btw) posted that he suspects the HP 300S is the same as the Casio 991DE. It would be interesting to see if the results from the HP 300S match up with HP results or Casio results, etc.
(06-30-2014 09:42 AM)HP67 Wrote: [ -> ]If you have an HP 300S and wouldn't mind doing this test http://www.rskey.org/~mwsebastian/miscprj/results.htm and posting your results here then I say thank you.
On the 300S the result is 9.000000001
On the 300S+ the result is 9.000000001
Sylvain
Thanks. Is that the full display precision? Many Casios on the results page show 15 digits.
(06-30-2014 10:38 AM)HP67 Wrote: [ -> ]Thanks. Is that the full display precision? Many Casios on the results page show 15 digits.
That's what I am seeing, I have not found any key that will show mantissa.
Thank you. In that case this doesn't match anything on rskey's results page.
(06-30-2014 11:05 AM)Sylvain Cote Wrote: [ -> ] (06-30-2014 10:38 AM)HP67 Wrote: [ -> ]Thanks. Is that the full display precision? Many Casios on the results page show 15 digits.
You can get the other digits by subtracting 9 from your answer. For example, on the HP 10s I get 9.000000002124:
sin-1 cos-1 tan-1 tan cos sin 9 = --> 9.000000002
Ans-9 = --> 2.124x10^-09
(06-30-2014 11:17 AM)HP67 Wrote: [ -> ]Thank you. In that case this doesn't match anything on rskey's results page.
I reread the manual, it's says that internal calculation is done with 15 digits but shows only 10 and I still not found any way to show the internal 15 digits
Sylvain
(06-30-2014 12:12 PM)Gerson W. Barbosa Wrote: [ -> ] (06-30-2014 11:05 AM)Sylvain Cote Wrote: [ -> ]That's what I am seeing, I have not found any key that will show mantissa.
Yes! great thinking and so simple. doing it I get 1.2467x10^-9
Interesting. Still doesn't match any published result.
gosh did anyone get 8.99999864267 like my 50G did?
(07-01-2014 02:22 AM)CosmicTruth Wrote: [ -> ]gosh did anyone get 8.99999864267 like my 50G did?
Uhm, yeah
8.99999864267 HP-19BII 27
8.99999864267 HP-20S f
8.99999864267 HP-22S f
8.99999864267 HP-27S 10,f
8.99999864267 HP-28C
8.99999864267 HP-28S 1
8.99999864267 HP-32S 10,f
8.99999864267 HP-32SII f
8.99999864267 HP-38G NEC D3004GD (CPU, HP 00048-80063), two KS0104, LH5347 (ROM, HP 1818-6119, Ver 1.67), MB84256C (RAM)
8.99999864267 HP-39G 1
8.99999864267 HP-42S f
8.99999864267 HP-48S
8.99999864267 HP-48G/G+/GX
8.99999864267 HP-48GII 45 ARM9 45
8.99999864267 HP-49G 4
8.99999864267 HP-49G+ 45 ARM9 45
8.99999864267 HP-50G ARM9
8.99999864267 HP-71B
8.99999864267 HP-75C 10
8.99999864267 HP-75D 10
8.99999864267 HP-87 8
(07-01-2014 06:25 AM)HP67 Wrote: [ -> ] (07-01-2014 02:22 AM)CosmicTruth Wrote: [ -> ]gosh did anyone get 8.99999864267 like my 50G did?
Uhm, yeah
Same results, incidentally.
http://www.hpmuseum.org/cgi-sys/cgiwrap/...ead=103151
Uhm, yeah
Thanks, and this looks perfect if you just FIX 5
