08-12-2021, 11:37 PM
SHARP PC-G850(V)(S): 107 keystrokes
Same number of keystrokes as the PC-E500(S) but one more for R. instead of F1 to run. The SHARP PC-G850(V)(S) has the same or similar keys (but no function keys) and similar BASIC.
SHARP PC-1403 to PC-1475: 118 keystrokes
An older series with the same or similar keys as the PC-E500(S), but with simpler BASIC, which has no impact on keying-in this simple program. However, [ENTER] is required after each pair of X,Y results are displayed (because all PC-14xx have a one-line LCD, except PC-1475 which has two lines. Thus adding 11 more keystrokes compared to the PC-E500(S).
Edit note: by comparison, the AREAD-based program for the PC-14xx series takes 111 keystrokes, here in full detail:
Setup: 33
Execution: 78
Total score: 111
Total score is 110 when entering B first before A for the first entry pair. This avoids having to clear the error [CL] when B is zero.
- Rob
[MODE] 1 PRO mode
1"A"A.A[ENTER] 8 1:"A"AREAD A
2"B"A.B[ENTER] 8 2:"B"AREAD B
3P.[x^2]A+A-[ln]B,[ln][x^2]B[ENTER] 15 3:PRINT SQU A+A-LN B,LN SQU B
[MODE] 1 RUN mode
3.12[DEF]A[CL]2.56[DEF]B 13
B/2[DEF]B 5
B/2[DEF]B 5
2*A[DEF]A 5
2*A[DEF]A 5
2*A[DEF]AB/2[DEF]B 10
B/2[DEF]B 5
1.32[DEF]B 6
18.59[DEF]A 7
17.63[DEF]A 7
2*B[DEF]B 5
2*B[DEF]B 5
Total score: 111
- Rob
