Full Version: hp prime calculations with units
Hi, there's some way to solve this calculus with units solved? Newton in this case? thanks.
(10_(kg)*2_(m)) / 1_(s^2).
On the ti-nspire (and numworks do the same) i've 20 _N. With hp prime the result is 20 (kg*m)/s^2.
(08-06-2021 10:04 PM)giubin Wrote: [ -> ]Hi, there's some way to solve this calculus with units solved? Newton in this case? thanks.
Dear Giubin,
You must use the "CONVERT" command to get the correct unit. Go to [Shift], [Units], where you will find a soft menu key called "Tools". Click on that, and you need the top command: "CONVERT". Use it like this: CONVERT(20 (kg*m)/s^2; 1_N), and it will give you the right answer: 20_N. Sincerely, Karel.
Hi Giubin,
another way is to use USIMPLIFY() which simplyfies the given unit in fact you don't know what unit that is.
Best regards
Frank
(08-14-2021 04:34 PM)froehlic Wrote: [ -> ]
Hi Giubin,
Best regards
Frank
Thanks, USIMPLIFY() is nice, but is strange that ti-nspire "solve" units automatically. That is a nice "simplify" Big Grin
Thanks, Giuseppe.
(08-14-2021 03:48 PM)cahlucas Wrote: [ -> ]
Dear Giubin,
Thanks, as suggested, maybe USIMPLIFY() is the answer for my "problem"! Sorry btw, i'm new with hp prime.
Many thanks, Giuseppe.
