07-23-2021, 07:38 AM
A thought crossed my mind. Does genuine HP microcode "remake" products like Swiss Micros and the Panamatik products lead to the possibility of other products? If code/microcode can be extracted from calculators, can the same be done with the 9800 series ROM cartridges?
I have no ability nor capacity to do such myself, but it seems the possibility of:
-- 3D print a cartridge case
-- extract the code/microcode of a cartridge
-- fabricate modern component innards and load the microcode
-- place all on a PCB with appropriate edge connector
should be possible.
i.e. is it possible for someone, having a cartridge, to fabricate a functional replica using methods similar to the afore-mentioned products?
I would think a market for this exists. Of course, a key assumption is the code extraction is non-destructive. If so, you'd think the user-base would offer ROM cartridges for code extraction, testing. Naturally assuming they will be returned timely and unmodified.
Anyone familiar with the design and construction of such "remake" products have an opinion?
should be possible.
