06-26-2021, 11:35 AM
06-26-2021, 12:53 PM
Are they both the same size disks?
If so, and also I assume you are using Series-80 (it's not stated):
COPY ":D700" TO ":D760"
should work.
should work.
06-26-2021, 01:12 PM
(06-26-2021 12:53 PM)rprosperi Wrote: [ -> ]Are they both the same size disks?
should work.
5 1/4 to 3 1/2
06-26-2021, 03:08 PM
Doesn't PIP work from inside CP/M?
pip b:=a:*.*[ORV]
b target disk, a source disk
O binary transfer
R copy system files
V verify each block
pip b:=a:*.*[ORV]
O binary transfer
R copy system files
V verify each block
06-26-2021, 08:05 PM
(06-26-2021 01:12 PM)hp41cx Wrote: [ -> ](06-26-2021 12:53 PM)rprosperi Wrote: [ -> ]Are they both the same size disks?
should work.
5 1/4 to 3 1/2
Of course, you did write that, I am asking about formatted size, e.g. SS/DD or DS/DD, etc.
Also, the target disk must be formatted before you do the copy, it is not a sector-by-sector copy, it's file-by-file, and the target is expected to be formatted by the INITIALIZE command.
