05-19-2021, 05:32 PM
Emu71/Win v1.14 is a maintenance update available at https://hp.giesselink.com.
This update improve the HP-IL handling of a broken loop between emulator and first virtual device. Sending a character to a first non answering device takes about 1.8s as timeout of the failed TCP/IP connect try. The actual version v1.14 has a total timeout of 20ms. This may cause trouble when Emu71 will run on a PC in Europe and the 1st virtual device on a PC in Australia, then the connect timeout maybe too short. Connects with programs running on the same PC or on a PC in the same local network have regular connect times <1ms. You may try this by opening a command shell and execute 'ping localhost'.
J-F also send me an update of his French keyboard macro include file avoiding some problems with autorepeated keys. The updated file is part of the complete installation package or of the basic KML script package skn71b.zip.
