Full Version: Prime pro new Android update - but no Python app ?!
The title says it all...
Confirmed.
It's nice to see it back in the play store, and it is a new version.
Version 2.1.24591 (2021 05 14), though the CAS remains at 1.5.0 (Version number unchanged).
It would be nice if it were followed by a Beta release with Python at some point.
i looked for some of the other new feature but did not find any. So most likely this version was an adaptation to the updated Android build process only, but is still the old firmware. Even though the firmware version number was increased.
It's strange.
I can go to HP Prime Pro App Install link. (below)
But I can't find HP Prime Pro App by searching play store like "HP Prime".
https://play.google.com/store/apps/detai...Fdownload2
-> One way to approach HP Prime Pro App
1. Search HP Prime
2. Select HP 12C Platinum Calculator
3. Touch HP Inc
4. In Apps list, there is HP Prime Pro?!
I've found that there are "HP Inc" and "HP Inc.".
(05-16-2021 09:17 AM)goetz Wrote: [ -> ]i looked for some of the other new feature but did not find any. So most likely this version was an adaptation to the updated Android build process only, but is still the old firmware. Even though the firmware version number was increased.
Got it in 1.
Basically, I had to get it back in the store before moving on to the new updates... gives a stable base to test from to ensure if problems happen it is not old but a new one.
I wish that you can set the orientation yourself (portrait, landscape), so that you can operate it optimally with a second APP in portrait or landscape format.
At the moment, this is unfortunately a pain under Android.
Is it possible to do a firmware update on the app as if it was the real device?
Did not find the original post, but from my memory some time ago it was mentioned that those emulators (on Android, Windows, iOS, Linux, macos) work completely differently and cannot just be updated with a calculator firmware image.
So I guess we have to wait for an updated version on the mobile platforms until it is ready. At least both paid and free versions are back in the Play store. If you are wondering, the beta version seems to be the same like the regular version (for Prime Pro on Android).
