05-12-2021, 09:10 PM
Now with Python I was curious what it is after all. So I decided to play a little bit around. You're of course invited to play with me. Subject is: drawing the Mandelbrot set
WARNING If you play with this, your Prime will reboot when you access an APP, definitely.
BUT this is not a great deal, you'll only lose the stack. To prevent from this, switch the Prime on and off. this will preserve the stack, but won't prevent from a reboot. That's what the "#%§'" is about. Really annoying.
I hope the moderators leave this here, because it's not meant as a great program but a playing field, to explore and exploit the capabilities of the implementation of Python on the Prime. Specifically LISTS, SETS and Drawing. Copy this code to a PPL-program. The name doesn't matter. Look at the top of the code for input syntax.
This program lives as a Python script in a PPL environment in HOME. It features 4 different kinds of output and 6 different depth of color. And it is really fast.
I'm a complete newbie to Python and inexperienced in programming, so bear with me if I talk about the obvious, but I hope to get some input as well.
Ref: #%§'
Next step should be zooming. Therefore MOUSE or KEY events would be very helpful.
Günter
#PYTHON name
from hpprime import *
from math import *
import sys
from urandom import *
"""Get arguments Input format at HOME
[[n]n]n.[m|0[a]]
n <depth> maximum depth of the Iteration
m <mag> Magnitude of colors i.e. number
of colors =mag^3 default is 4,
giving 64 colors
a <art> how to plot
0: rolling from left to right
1: roll by tiles
2: kind of dust
3: another dust, more random takes longer
"""parsing input. Bit tricky, <round>
and <int> needed due to binary
character. N >= 1000 results in error
inp=sys.argv[0]
inp=float(inp)
inp=modf(inp)
depth=int(max(inp[1],10))
inp=round(inp[0],2)*10
inp=modf(inp)
mag=(4 if (inp[1] <= 1 or inp[1]>6)\
else int(inp[1]))
inp=modf(inp)
art=int(inp[1])
# set black and white
black=0x000000
white=0xffffff
""" put a pixel at x,y with color
determined by the iteration at this
specific point
def paint(x9,y9):
z = complex(0,0)
c = complex(3*x9/319-2*1,\
-2.25*y9/239+1.125)
i = 0
while (i < depth) and abs(z) < 2:
i = i + 1
z = z**2+c
rgb = pal[i%len(pal)]
if i==depth :
pixon(0,x9,y9,0)
else:
pixon(0,x9,y9,rgb)
# When finished display a small
# white square top-left
def finish():
fillrect(0,0,0,10,10,white,white)
#clear screen black
fillrect(0,0,0,320,240,black,black)
create color palette with
"LIST Comprehension" at first for
<pal0> calculate how many elements
for each of red, green, blue.
then for <pal> combine each of the
elements of one color with each
element of the other colors.
Thus number of colors = mag^3
elem=(255/(mag-1))
pal0=[(int(iter*elem)) for iter \
in range(mag)]
#pal0.reverse
pal=[(b*256**2 + g*256 + r ) \
for b in pal0 \
for g in pal0 \
for r in pal0]
pal.sort()
# screen filled from top to bottom,
# left to right, the simplest way
if art==0:
for x in range(320):
for y in range(240):
paint(x,y)
finish()
# Pixel put pseudo randomly,takes
# much longer. Picture completed
# by using <art1> after this loop
if art==3:
for i in range(40**3):
paint(randint(0,320),randint(0,240))
art=1
# Tiles are distributed randomly and
# then filled randomly very nice,
if art==1:
i=0
Tiles=[]
for TileX in range(0,320,32):
for TileY in range(0,240,16):
Tiles.insert(randint(0,len(Tiles)),(TileX,TileY))
Pixels=[]
for PixelX in range(32):
for PixelY in range(16):
Pixels.insert(randint(0,len(Pixels)),(PixelX,PixelY))
P0=0
for PixX in range(32):
for PixY in range(16):
px,py=Pixels[P0]
P0+=1;
#on the virt. prime uncomment next line
#eval("wait(0.01")
for t0 in range(len(Tiles)):
tx,ty=Tiles[t0]
paint(tx+px,ty+py)
#paint(Tiles[t0]
finish()
# Pixels distributed by tiles. You
# won't see a difference to <art0>
# on the Virtual Prime)
if art==2:
t0=10
tx=int(320/t0)
ty=int(240/t0)
y1=0
for x1 in range(tx,321,tx):
for y1 in range(ty,241,ty):
for x in range(x1-tx,x1):
# on the virtual Prime uncomment the next line
#eval("Wait(0.001)")
for y in range(y1-ty,y1):
paint(x,y)
finish()
eval("WAIT")
#end
EXPORT mandel(a)
PYTHON(name, a);
Ref: #%§'
- The reboot problem needs to be solved. has been reported
- sys.argv errors out when value is >999
- get something from the mouse
- get something from the keyboard
- read the value of a pixel
Günter
