05-09-2021, 09:52 AM
After repairing an HP-67, I made a copy of the label on the back with a graphics program. Maybe it's useful to someone else too. If you want, you can download the copy of the label here
Password is hew-pack-67
After removing the original label, I put the copy on the calculator and kept the original for later.
I printed out the copy with a laser printer on normal paper and then treated it with a matt varnish. The label treated in this way was then attached to the calculator with a thin double-sided adhesive film.
11.05.2021
I've changed the pdf files. The resolution was too low.
11.05.2021
Correction of a typographical error (BRITISCH... to BRITISH...)
11.05.2021
11.05.2021
