I finally got around to replacing worn and missing feet for a few voyagers and I found some excellent material on the Bay.
5x7" sheet - 1/16" thick and cuts smooth. A little piece of double sided tape and done. I thought about a spray adhesive but will keep that in reserve if the tape fails.
My wife certainly raised an eyebrow when a mailer from Ruby's Rubbers arrived.
Link:
https://www.ebay.com/itm/192212457857
-Bill
Hi Bob,
I did check those sweet feet out and TBH its not really that much work once you have cut one foot for a template. Its amazing the amount of feet that are worn and missing. I am doing about 4 calcs and $4 vs ~ $20 won in my "thrifty" perspective.
Thanks and trust me if it was one set I would do the stick it and forget option.
BTW I think the CalculatorStore is giving a free set of 41 feet with a 40+ Euro purchase right now.
Take Care,
Thrifty Bill
Thanks for the information.
I bought a set of rubber feet and it allowed me to fix 3 voyagers, it's really annoying to try to type things in on a hard desk with a wobble.
Thanks again for sharing.
I used the rubber self adhesive material from bicycle tire repair kit (discard the liquid glue tube), cut to size. I 3D printed out a template so that I can cut them reliably with a knife.
Shop around and you'll find the right size and thickness mimic to the original.
Hi everyone,
Here's my 2-cents, using an old bike tyre innertube, cut out the size to fit the recess, stick on some double sided tape & insert into the footing/slot.
I have a card reader with a recessed foot slot, way over 10 years ago the rubber was lost. Since then the rubber innertube insert has worked faultlessly.
DA.
