05-02-2021, 11:55 AM
I'm in the process of converting the function library for the BBC micro:bit for use with the Prime (and I'll share it here when ready).
On the surface of things, this may seem a tad odd, but the micro:bit really comes into its own as a low-cost alternative to HP DataStream products. The kit detailed below is £46 (here in the UK) and contains 37 different sensor types (these obviously lack the precision of high-end lab kit). Even if you do the majority of your MicroPython work is done via a desktop OS, having the ability to edit your scripts in situ where you're taking senor measurements will be a really cool addition to their broader educational value. The v2 micro:bit itself is approx £20-25 and packs a lot of punch for such a low-cost device.
Sensor kit on Amazon
BBC micro:bit of Amazon
![[Image: 7dEq8O]](https://cdn-std.droplr.net/files/acc_122537/7dEq8O)
