05-01-2021, 06:22 PM
Hello, INPUT cms does not work in CAS MODE, the following code although it is for home mode, it can be executed in CAS mode
try to test input_(x) then type '987' in single quotes, in the end the input variable is not stored in memory = (any way to do it?
PHP Code:
export input_(var)
begin
local ok;
ok:=input(eval(var));
if ok then
print( var );
print( eval(var));
return eval(var);
end;
end;
