Hi, is there a way to graph polar and cartesian on the same graph on the HP Prime? In other words, can I graph r(theta) = r*sin(theta) and x^2+y^2=1 on the same plot?
Thanks.
A less mathematical alternative could put the two graphs on the same screen rather than on the same graph.
I was thinking:
Draw a graph
Save a bitmap
Draw 2nd graph
Load image of 1st graph with some transparency.
Which has the advantage that you don't need to rewrite every equation you may want to share a graph with.
But it's not exactly on the same graph.
Thanks guys, I'll keep that in mind. These ways are a good work around to check if my Cartesian to Polar conversions are correct.
Doesn't the Geometry app have this functionality? I've haven't used it much but I know there's the option for all the different types of graphing.
Ah yes the Geometry app! This is what I was looking for! You can use plotpolar() and plotimplicit() to graph your polar and cartesian functions respectively. Thank you TheLastMilennial! I watched your in-depth review on the Prime G2 not to long ago and it was great!
