05-01-2021, 12:22 AM
Hello
In this post I am going to put a series of examples of CAS-type programs
SCRIPT 01: obtaining the solutions of the quadratic equation
You can run the following sentences line by line in the CAS history, please let me know if the results on your calculator are different.
Change manually Simplify mode to None [shift] + [CAS (settings)]
autosimplify cmd of Xcas is not yet available in firmware 2021
autosimplify (0); // Xcas only = (
![[Image: autosimplify_flag_image00.jpg]](https://www.eonicasys.com.co/math/system/hp_prime/io/images/autosimplify_flag_image00.jpg)
SCRIPT 01
Please inform me if I am wrong.
What other calculator with CAS and original firmware can do the above? I think no one, only the HP-Prime with Xcas, simply because they (TI; Texas Instruments, CASIO, Sharp, Numworks ...) can't control the simplification type of output.
the same script above but with comments
the same script above but using SUBST to make changes to the expression without converting to text strings
as a program and 2D printing
quadraticform() [enter]
![[Image: quadraticform_scriptcas_image00.png]](http://eonicasys.com.co/math/system/hp_prime/scripts/images/quadraticform_scriptcas_image00.png)
Printing with the #183 character "·" would look more compact and legible, this will allow to display the "*" symbol as a "·", this could be changed by configuration, depending on how you want to display the multiplication operator. This feature was available on the hp48gx
using optional template for cas prg
Script using only the ANS variable
![[Image: quadraticform_scriptcas_image01.png]](http://eonicasys.com.co/math/system/hp_prime/scripts/images/quadraticform_scriptcas_image01.png)
as prgm
in writing.
SCRIPT 01
PHP Code:
autosimplify(0); // Xcas only =(
purge(a,b,c,x,equ0,equ1,equ2);
equ0:= (a*x^2+b*x+c) = 0; // [enter] (a*x^2+b*x+c) = 0
equ := equ0 * 4*a; // [enter] (4*(a*x^2+b*x+c)*a) = 0
equ := expand( equ ); // [enter] (4*a^2*x^2+4*a*b*x+4*a*c) = 0
equ := equ + b^2; // [enter] (4*a^2*x^2+4*a*b*x+4*a*c+b^2) = (b^2)
equ := equ - 4*a*c; // [enter] (4*a^2*x^2+4*a*b*x+4*a*c+b^2-4*a*c) = (b^2-4*a*c)
equ := simplify( equ ); // [enter] (4*a^2*x^2+4*a*b*x+b^2) = (-4*a*c+b^2)
equ := factor( equ ); // [enter] ((2*a*x+b)^2) = (-4*a*c+b^2)
equ := √( equ ); // [enter] (ABS(2*a*x+b)) = (sqrt(-4*a*c+b^2))
equ := expr( replace( string( equ ), "abs", "" ) ); // [enter] (2*a*x+b) = (sqrt(-4*a*c+b^2))
equ := equ - b; // [enter] (2*a*x+b-b) = (sqrt(-4*a*c+b^2)-b)
equ := simplify( equ ); // [enter] (2*a*x) = (-b+sqrt(-4*a*c+b^2))
equ := equ / ( 2*a ); // [enter] (2*a*x/(2*a)) = (-b+sqrt(-4*a*c+b^2))/(2*a)
equ := simplify( equ ); // [enter] x = (-b+sqrt(-4*a*c+b^2))/(2*a)
equ1 := expr( replace( string( equ ), "x", "x1" ) ); // [enter] x1 = (-b+sqrt(-4*a*c+b^2))/(2*a)
equ2 := expr( replace( string( equ1 ), "x1", "x2" )); // [enter] x2 = (-b+sqrt(-4*a*c+b^2))/(2*a)
equ2 := expr( replace( string( equ2 ), "-b+", "-b-" ) ); // [enter] x2 = (-b-sqrt(-4*a*c+b^2))/(2*a)
PHP Code:
autosimplify(0);
equ := equ0 * 4*a;
equ := equ + b^2;
equ := equ - 4*a*c;
equ := √( equ );
equ := equ - b;
PHP Code:
autosimplify(0);
equ := equ0 * 4*a;
equ := equ + b^2;
equ := equ - 4*a*c;
equ := √( equ );
equ := subst(equ,'abs', nop);
equ := equ - b;
equ1 := subst(equ,x, x1); // or, equ1 := subst(equ,x=x1);
equ2 := subst(equ1,x1, x2); // or, equ2 := subst(equ1,x1=x2);
equ2 := subst(equ1,"-b+", "-b+");
PHP Code:
#cas
//Deduction Quadratic Formula
quadraticform():=
begin
autosimplify(0);
equ0:= (a*x^2+b*x+c) = 0; print(equ0);
equ := equ0 * 4*a; print(equ);
equ := expand( equ ); print(equ);
equ := equ + b^2; print(equ);
equ := equ - 4*a*c; print(equ);
equ := simplify( equ ); print(equ);
equ := factor( equ ); print(equ);
equ := √( equ ); print(equ);
equ := subst(equ,'abs', nop); print(equ);
equ := equ - b; print(equ);
equ := equ / ( 2*a ); print(equ);
equ1 := subst(equ,x=x1); print(equ1);
equ2 := subst(equ2,"-b+", "-b+"); print(equ2);
return [equ0, equ1, equ2];
end;
PHP Code:
#cas
function name(args)
return ...
end;
#end
#cas
function quadraticform()
autosimplify(0);
end;
PHP Code:
(a*x^2+b*x+c) = 0;
Ans*4*a;
expand(Ans);
Ans+b^2;
Ans-4*a*c;
simplify(Ans);
factor(Ans);
√(Ans);
subst(Ans,'abs', nop);
Ans-b;
simplify(Ans);
Ans/(2*a);
simplify(Ans);
expr(replace(string(Ans),"-b+","-b-"));
as prgm
PHP Code:
#cas
function quadraticform_1()
(a*x^2+b*x+c) = 0;
Ans*4*a;
expand(Ans);
Ans+b^2;
Ans-4*a*c;
simplify(Ans);
factor(Ans);
√(Ans);
Ans-b;
simplify(Ans);
Ans/(2*a);
simplify(Ans);
return Ans;
end;
in writing.
