04-24-2021, 11:08 PM
HP49-50G Square root many digits
Of course there are plenty ways of calculating the square root.
Here is a sequence of commands included in one single program that can be used as a user-assigned key.
ROOT2
\<< "\[] 1 Arg
\[] Put below 101 if
you want 100 digits
" DROP 51 \-> digit
\<< -105 CF DUP "\v/" SWAP + SWAP DUP \v/ SWAP DUP \->STR SWAP FP \-> nb f
IF f 0 \=/
THEN nb "." POS 1 - \-> pos
\<< nb "." "" SREPL DROP DUP SIZE \-> nb1 sz1
\<< pos 2 / FP 0 ==
IF
THEN sz1 2 / FP 0 \=/
IF
THEN nb1 0 + 'nb1' STO
END
ELSE sz1 2 / FP 0 ==
IF
END
END nb1
ELSE nb "." "" SREPL DROP
END
\>> DUP SIZE 2 / FP 0 == "" 0 IFTE SWAP + DUP SIZE 2 / \-> n sz
\<< { } 0 sz 1 -
FOR i n i 2 * 1 + DUP 1 + SUB OBJ\-> +
NEXT 'n' STO 0 0 0 0 1 \-> a b m s k
WHILE k digit <
REPEAT a b - 100 * 'a' STO k sz \<=
IF
THEN n k GET 'a' STO+
END 1 'k' STO+ 9 's' STO
WHILE 20 m * s + s * a >
REPEAT -1 's' STO+
END 20 m * s + s * 'b' STO 10 m * s + 'm' STO
END m \->STR \-> st
\<< st 2 50
FOR i st i digit 1 - SUB OBJ\-> 0 ==
IF
THEN 1 i 1 - SUB digit 1 - 'i' STO
END
NEXT OBJ\-> DUP2 ==
IF
THEN SWAP DROP
END
52.3 ASN
(Or 52.1 ASN or 52.2 ASN.)
We assign (ASN command) this program to the square root key 52.
Example 1
Introduce for instance 9
and LS User
Then sqrt-key (under the EVAL-key).
You get in level stack 2 sqrt(9)
3 in level stack 1
Example 2
Introduce now 9
and LS User
You get in level stack 3 sqrt(900)
30 in level stack 2 (normally an approximation).
3, which represents the first "50 digits, less the redundant zeroes".
Example 3
Insure yourself that you are in exact mode.
Type 1234567891234
Then press ENTER
Then press a second time ENTER
Ptess * in order to multiply both identical numbers in the stack.
You should get 1524157878065965654042756
Now LS User
"Sqrt(1524157878065965654042756)"
In stack level 2 the approximative result 1.23456789124E12
And 1234567891234 in level 1 (the zeroes after the second digit 4 on the right are left out).
Example 4
Type as argument
1524157878065965654042757
(757 at the end, and not 756).
Now LS User
Example 4
Type as argument
Now LS User
"Sqrt(1524157878065965654042757)"
And 12345678912340000000000004050000032806863265750682 in level 1. Note that, this time, the zeroes after the second digit 4 on the right do appear as, after them, do appear also different ≠0-digits.
Example 5
12.178 LS-User SQRT-Key
Gives
"sqrt(12.178) " in stack level 3
3.48969912743 in stack level 2
and, in stack level 1, 34896991274320484031821999216879351359311052016725
Example 6
Sqrt 1.2178
Gives, in stack level 3,"sqrt(1.2178)"
1.10353975914 in stack level 2
11035397591387453041375873710499307803985079728862.
Seems to work fine.
Best is to use the phone EMU48 application if you don't want to way too much for the answers.
Note that you can modify the number of digits to be calculated and shown.
Gil Campart
ROOT2
\<< "\[] 1 Arg
you want 100 digits
" DROP 51 \-> digit
IF f 0 \=/
\<< pos 2 / FP 0 ==
IF
IF
END
IF
END
END nb1
END
\<< { } 0 sz 1 -
WHILE k digit <
IF
REPEAT -1 's' STO+
END m \->STR \-> st
\<< st 2 50
IF
END
NEXT OBJ\-> DUP2 ==
IF
THEN SWAP DROP
END
52.3 ASN
Example 1
and LS User
3 in level stack 1
Example 2
Introduce now 9
and LS User
Example 3
Type 1234567891234
Then press ENTER
Now LS User
Example 4
Type as argument
Now LS User
Example 4
Type as argument
Now LS User
Example 5
Gives
Example 6
Sqrt 1.2178
Seems to work fine.
Gil Campart
