04-24-2021, 01:23 PM
I have put some "Percentage Problem" for some compatible calculator.
These Percentage Problem not found in most of the manual such as Percent of Total, Pricing Calculations etc.
This Percentage Problem I used the Casio MS-20UC with this calculator to calculate
Percent addition or subtraction it use this steps: amount [x] rate [%] then [+] or [-] style.
Also this calculator must have constant arithmatic when double press for example [+] [+]
the display will shown little k on screen.
Here is the PDF file:
https://www.dropbox.com/s/p8pqirx8aadhlk...m.pdf?dl=0
Recommend to print this out.
Gamo 4/2021
Gamo 4/2021
