04-17-2021, 01:11 PM
From the recent public beta announcement,
I thought someone might benefit from seeing the syntax for this. And while technically correct that PPL does not support default arguments, you can still get the equivalent of default arguments as shown below.
Here's an example of multiple arguments using the same function name defined with different number of arguments.
And here's a simple example of the variable argument syntax.
IMHO, these are nice additions to PPL.
(04-14-2021 06:32 AM)Tim Wessman Wrote: [ -> ][*]Able to have multiple functions of same name with different number of arguments (no default arguments though)
// quadratic formula demonstration of default parameters
// QF(a, b, c)
// QF(b, c) assumes a=1
// QF(c) assumes a=1, b=0
EXPORT QF(a,b,c)
LOCAL d;
d:=b^2-4*a*c;
RETURN (−b+{1,−1}*√(d))/(2*a);
EXPORT QF(b,c)
QF(1,b,c);
EXPORT QF(c)
QF(1,0,c)
// Parallel Resistors: Adds resistors in parallel.
// Requires at least two parameters, a and b.
// The rest of the parameters are put in list c.
// If only two parameters are given, then c is {}.
// PPL allows up to 16 parameters total,
// so a and b plus 14 more in list c
EXPORT ParallelResistors(a,b,...c)
c:=CONCAT(a,b,c);
RETURN 1/ΣLIST(1/c);
