04-16-2021, 11:17 PM
Hello hp¹s
In firmware 2021, we have a new PRINT2D command in math book print format. =]
A: PRINT2D does not work in CAS mode =(
B: The tab symbol must be invisible in terminal view and visible in edit as ⇥
Basic escape characters work great in the code editor, but not yet in the history view =(
Test PRINT & PRINT2D cmds
HOME MODE:
Test print (lowercase) cmd
CAS MODE:
output comparison between HOME and CAS
![[Image: print2d_hp_prime_2021_img00.png]](https://www.eonicasys.com.co/math/system/hp_prime/io/images/print2d_hp_prime_2021_img00.png)
Quote:PRINT2D Syntax:
PRINT2D(obj, [font], [color], flags)
PRINTED )
Prints either the result of expr or string to the terminal. The display will be done using textbook display
PHP Code:
PRINT( "Hello\n\tworld \\ \" " ); // Hello world \ "
PRINT2D( "Hello\n\tworld \\ \" " );
print( "Hello\n\tworld \\ \" " );
HOME MODE:
PHP Code:
EXPORT print_cmds_home()
PRINT(); // Clear terminal output
PRINT( (50 - 5*6) / 4 ); // 5, evaluates, ok
PRINT2D( (50 - 5*6) / 4 ); // 5, evaluates, ok
PRINT( "\n" ); // new line, ok
PRINT( quote(5 ^ 2) ); // 5^2, 1D without evaluating, ok
PRINT( '5 ^ 2' ); // 5^2, 1D without evaluating, ok
PRINT2D( quote(5 ^ 2) ); // 5² , 2D without evaluating, ok
PRINT2D( '5 ^ 2' ); // 5² , 2D without evaluating, ok
PRINT( 5 ^ 2 ); // 25, ok
PRINT2D( 5 ^ 2 ); // 25, ok
PRINT( "\n" );
PRINT( '(50 - (5*6)) / 4' ); // 1D without evaluating, ok
PRINT2D( '(50 - (5*6)) / 4' ); // 2D without evaluating, ok
PRINT( "\n" );
PRINT2D( "Hello\nworld" );
PRINT( "\n" );
PRINT2D( '17 / 3' ); // 17/3, rational division without evaluating, ok
PRINT2D( 17 / 3 ); // 5.6666... , approximate value calculation, ok
PRINT( "\n" );
PRINT2D( 'floor(17 / 3)' ); // print as function floor(17 / 3), but ⌊ 17/3 ⌋ is real 2D mathbook print, 8970 (⌊) & 8971(⌋) unicode char
PRINT2D( floor(17 / 3) ); // 5, ok, floor division discards the fractional part
PRINT( "\n" );
PRINT2D( 'ceiling(17 / 3)' ); // print as ceiling(17 / 3), but ⌈ 17/3 ⌉ is real 2D mathbook print, 8968(⌈)/8969(⌉) unicode char
PRINT2D( ceiling(17 / 3) ); // 6
PRINT( "\n" );
PRINT2D( '17 MOD 3' ); // 17 MOD 3
PRINT2D( 17 MOD 3 ); // 2, ok, the MOD operator returns the remainder of the division
PRINT( "\n" );
PRINT2D( 'abs(3+4*i)' ); // | 3 + 4i |, ok
PRINT2D( abs(3+4*i) ); // 5, ok
PRINT( "\n" );
RETURN( "Done" );
CAS MODE:
PHP Code:
#cas
print_cmds_cas():=
print(); // Clear terminal output
print( (50 - 5*6) / 4 ); // 5, evaluates, ok
print( "\n" ); // still not print new line =(
print( string(quote(5 ^ 2) )); // "5^2", 1D without evaluating
print( string('5 ^ 2') ); // "5^2", 1D without evaluating
print( quote(5 ^ 2) ); // 5² , 2D without evaluating, ok
print( '5 ^ 2' ); // 5² , 2D without evaluating, ok
print( 5 ^ 2 ); // 25, ok
print( "\n" );
print( string('(50 - (5*6)) / 4' )); // 1D without evaluating
print( '(50 - (5*6)) / 4' ); // 2D without evaluating, ok
print( "\n" );
print( "Hello\n\tworld \\ \" " ); // Hello world \ "
print( "Hello\nworld" );
print( "\n" );
print( '17 / 3' ); // 17/3, rational division without evaluating, ok
print( 17 / 3. ); // 5.6666... , approximate value calculation, ok
print( "\n" );
print( 'floor(17 / 3)' ); // print as function floor(17 / 3), but ⌊ 17/3 ⌋ is real 2D mathbook print, 8970 (⌊) & 8971(⌋) unicode char
print( floor(17 / 3) ); // 5, ok, floor division discards the fractional part
print( "\n" );
print( 'ceiling(17 / 3)' ); // print as ceiling(17 / 3), but ⌈ 17/3 ⌉ is real 2D mathbook print, 8968(⌈)/8969(⌉) unicode char
print( ceiling(17 / 3) ); // 6
print( "\n" );
print( '17 MOD 3' ); // 17 MOD 3
print( 17 MOD 3 ); // 2, ok, the MOD operator returns the remainder of the division
print( "\n" );
print( 'abs(3+4*i)' ); // | 3 + 4i |, ok
print( abs(3+4*i) ); // 5, ok
print( "\n" );
RETURN( "Done" );
#end
