04-13-2021, 04:00 PM
This is a simple unit conversion program built mainly using the conversion factors from the 48.
To use, RUN CONV, enter a value to convert, enter the abbreviation of the units to convert from, and then enter the abbreviation of the units to convert to. The converted value will be displayed, and also available in RES.
The program will make sure you don't attempt to convert across categories of units, e.g. feet to Newtons, and will display "INCONSISTENT UNITS" if you attempt this.
Example:
Convert 5 fl.oz. to mL:
RUN CONV
? 5
FROM? FLOZ
TO? ML
147.867647812 ML
Unit abbreviations should be entered in uppercase, with two exceptions: Greek mu is replaced with lowercase u in microns and microliters, and the speed of light is entered as lowercase c so as not to confuse it with Celsius. Temperatures are entered as a single character with no degree symbol.
To add more units, simply add additional program lines to check U$ and set F accordingly. To find the value to use for F, convert 1 of the new unit to the base unit (the first entry in each group where F=1). So if you frequently use picoliters, add line 156 that sets F=1E-15 (1 pL converted to m^3) when U$="PL".
Entirely new categories of units can be added by setting C at the beginning of each category block. Or you can delete lines/categories you don't need to save memory.
Code is listed below, and a LIF file is attached. On-device program size is 2,414 bytes.
[attachment=9361]
Example:
RUN CONV
? 5
FROM? FLOZ
TO? ML
147.867647812 ML
0001 DIM X,F,O,C,D,U$
0010 INPUT X
0020 INPUT "FROM? ";U$ @ GOSUB 100
0021 IF C=0 THEN GOTO 90
0022 D=C @ X=(X-O)*F
0030 INPUT "TO? ";U$ @ GOSUB 100
0031 IF C=0 THEN GOTO 90
0032 IF C<>D THEN DISP "INCONSISTENT UNITS" @ END
0040 X=X/F+O @ PRINT X;U$ @ END
0090 DISP "NOT FOUND" @ END
0100 O=0 @ C=1 @ REM LENGTH
0101 IF U$="M" THEN F=1 @ RETURN
0102 IF U$="CM" THEN F=.01 @ RETURN
0103 IF U$="MM" THEN F=.001 @ RETURN
0104 IF U$="KM" THEN F=1000 @ RETURN
0105 IF U$="IN" THEN F=.0254 @ RETURN
0106 IF U$="FT" THEN F=.3048 @ RETURN
0107 IF U$="MI" THEN F=1609.344 @ RETURN
0108 IF U$="YD" THEN F=.9144 @ RETURN
0109 IF U$="LYR" THEN F=9.46052840488E+15 @ RETURN
0110 IF U$="NMI" THEN F=1852 @ RETURN
0111 IF U$="FATH" THEN F=1.82880365761 @ RETURN
0112 IF U$="MIL" THEN F=.0000254 @ RETURN
0113 IF U$="u" THEN F=.000001 @ RETURN
0120 C=2 @ REM AREA
0121 IF U$="SQM" THEN F=1 @ RETURN
0122 IF U$="SQCM" THEN F=.0001 @ RETURN
0123 IF U$="SQYD" THEN F=.83612736 @ RETURN
0124 IF U$="SQFT" THEN F=.09290304 @ RETURN
0125 IF U$="SQIN" THEN F=.00064516 @ RETURN
0126 IF U$="SQKM" THEN F=1000000 @ RETURN
0127 IF U$="HA" THEN F=10000 @ RETURN
0128 IF U$="SQMI" THEN F=2589988.11034 @ RETURN
0129 IF U$="ACRE" THEN F=4046.87260987 @ RETURN
0140 C=3 @ REM VOLUME
0141 IF U$="M^3" THEN F=1 @ RETURN
0142 IF U$="CM^3" THEN F=.000001 @ RETURN
0143 IF U$="YD^3" THEN F=.764554857984 @ RETURN
0144 IF U$="FT^3" THEN F=.028316846592 @ RETURN
0145 IF U$="IN^3" THEN F=.000016387064 @ RETURN
0146 IF U$="L" THEN F=.001 @ RETURN
0147 IF U$="GAL" THEN F=.003785411784 @ RETURN
0148 IF U$="PT" THEN F=.000473176473 @ RETURN
0149 IF U$="QT" THEN F=.000946352946 @ RETURN
0150 IF U$="ML" THEN F=.000001 @ RETURN
0151 IF U$="CU" THEN F=.0002365882365 @ RETURN
0152 IF U$="FLOZ" THEN F=2.95735295625E-5 @ RETURN
0153 IF U$="TBSP" THEN F=1.47867647813E-5 @ RETURN
0154 IF U$="TSP" THEN F=4.92892159375E-6 @ RETURN
0155 IF U$="uL" THEN F=.000000001 @ RETURN
0160 C=4 @ REM MASS
0161 IF U$="KG" THEN F=1 @ RETURN
0162 IF U$="G" THEN F=.001 @ RETURN
0163 IF U$="MG" THEN F=.000001 @ RETURN
0164 IF U$="LB" THEN F=.45359237 @ RETURN
0165 IF U$="OZ" THEN F=.028349523125 @ RETURN
0166 IF U$="CT" THEN F=.0002 @ RETURN
0167 IF U$="ST" THEN F=6.35029 @ RETURN
0180 C=5 @ REM FORCE
0181 IF U$="N" THEN F=1 @ RETURN
0182 IF U$="LBF" THEN F=4.44822161526 @ RETURN
0200 C=6 @ REM ENERGY
0201 IF U$="J" THEN F=1 @ RETURN
0202 IF U$="ERG" THEN F=.0000001 @ RETURN
0203 IF U$="KCAL" THEN F=4186.8 @ RETURN
0204 IF U$="CAL" THEN F=4.1868 @ RETURN
0205 IF U$="FT*LBF" THEN F=1.35581794833 @ RETURN
0206 IF U$="THERM" THEN F=105506000 @ RETURN
0207 IF U$="MEV" THEN F=1.60219E-13 @ RETURN
0208 IF U$="EV" THEN F=1.60219E-19 @ RETURN
0209 IF U$="BTU" THEN F=1055.05585262 @ RETURN
0220 C=7 @ REM TEMPERATURE
0221 IF U$="C" THEN F=1 @ O=0 @ RETURN
0222 IF U$="F" THEN F=5/9 @ O=32 @ RETURN
0223 IF U$="K" THEN F=1 @ O=273.15 @ RETURN
0224 IF U$="R" THEN F=5/9 @ O=491.67 @ RETURN
0240 C=8 @ REM PRESSURE
0241 IF U$="PA" THEN F=1 @ RETURN
0242 IF U$="ATM" THEN F=101325 @ RETURN
0243 IF U$="BAR" THEN F=100000 @ RETURN
0244 IF U$="PSI" THEN F=6894.75729317 @ RETURN
0245 IF U$="TORR" OR U$="MMHG" THEN F=133.322368421 @ RETURN
0246 IF U$="INHG" THEN F=3386.38815789 @ RETURN
0247 IF U$="INH2O" THEN F=248.84 @ RETURN
0248 IF U$="CMH2O" THEN F=97.968503937 @ RETURN
0249 IF U$="KG/CM^2" THEN F=98066.5 @ RETURN
0260 C=9 @ REM SPEED
0261 IF U$="M/S" THEN F=1 @ RETURN
0262 IF U$="CM/S" THEN F=.01 @ RETURN
0263 IF U$="FT/S" THEN F=.3048 @ RETURN
0264 IF U$="KPH" THEN F=1/3.6 @ RETURN
0265 IF U$="MPH" THEN F=.44704 @ RETURN
0266 IF U$="KT" THEN F=.514444444445 @ RETURN
0267 IF U$="c" THEN F=299792458 @ RETURN
0268 IF U$="LYR/HR" THEN F=2.62792455691E+12 @ RETURN
1000 C=0 @ RETURN
[attachment=9361]
