Recently I try this program called 16-Point Gaussian Quadrature found
in the HP-11C Solutions Handbook on page 30
So this program do the Integration problem. I have try diffrent problem
and the answer come out very well except one.
This one doesn't give enough accuracy when compare to the
Integration Function on the HP-15C
Here is the problem: ∫ 0 to 2 √4 - X² dx = Pi = 3.141592654
On the HP-11C and HP-15 Equation is
[X²] [4] [X<>] [-] [√]
Answer on HP-11C is 3.141722674
Answer on HP-15C is 3.141592653
So is program provided on the HP-11C Solutions Book only give three
decimal place accuracy or it only happen to certain problem.
Gamo
(04-09-2021 05:17 AM)Gamo Wrote: [ -> ]Here is the problem: ∫ 0 to 2 √4 - X² dx = Pi = 3.141592654
This looks right and not bad for 16 points. 16 points will only give you a (rough) approximation of \( \int_0^2 \sqrt{4-x^2}\,dx \).
Gausss 10 point: 3.14209916979661
Gauss Kronrod 21 point: 3.14161975053083
By comparison (edited to add more examples):
Romberg 524289 points (1e-9 error threshold) gives 3.14159265256818
Romberg 16385 points (1e-7 error threshold) gives 3.14159265256818
Tanh-Sinh 56 points (1e-9 error threshold) gives 3.14159265358672
Tanh-Sinh 30 points (1e-7 error threshold) gives 3.14159265358975
Adaptive Simpson 417 points (1e-9 error threshold) gives 3.14159111522653
Adaptive Simpson 153 points (1e-7 error threshold) gives 3.14159111489381
- Rob
Both Gaussian and Romberg quadrature are based on fitting the curve to polynomial.
When X ≈ 2, the curve fall off a cliff, which is hard to curve fit by polynomial.
HP-15C does a u-substitution, which in this case, removed the cliff entirely.
int(√(4-x^2), x=0..2.)
= int(4*√(1-x^2), x=0..1.)
= int(24*u*(1-u) * √(1 - (u*u*(3-2*u))^2), u = 0..1.)
Try this u-transformed function, 16-points should converge to pi pretty good.
Another way is to avoid the cliff.
y = √(4-x²), x≥0 → x = √(4-y²)
Note the x/y symmetry, instead of integrating from 0 to 2, we can do 0 to √2
With limit = [0,√2], doubled the result over-counted by a square, area = (√2)² = 2
int(√(4-x^2), x=0..2.) = int(√(4-x^2), x=0..√(2.)) * 2 - 2
The HP-15C Integration Function is excellent.
I will go back to read more information about this
great integration function in the Advance Functions Handbook.
Gamo
I put that exact integral on my last calculus test. :-)
(04-09-2021 04:41 PM)Albert Chan Wrote: [ -> ]Try this u-transformed function, 16-points should converge to pi pretty good.
The TI-Nspire calculator uses this u-transformation with a 15 point Gauss-Kronrod method.
