04-06-2021, 02:50 PM
(Crosspost from general iHP48 thread)
I found instructions for installing Meta Kernel on iHP48, but can't get them to work (even after sorting out the confusing line breaks and step numbering errors):
After hitting [EVAL] (step 10 above) I get
THEN Error:
Too Few Arguments
Also, what should actually be on the stack for steps 6 and 7: M or 'M'?
- Create a new HP48GX calculator
- Type MERGE1 into the calculator (without the "") and press [ENTER]
- Go to Fetch... and download the Meta-Kernel from the web
- Now use the Load Object... function to load the following file into the calculator: /Downloads/MetaKernel2.30/Disk/Install/MKRAM.KER
- Go to the calculator
- Type 'M' and hit [STO]
- Type again 'M' into the stack for later. An 'M' should reside on the stack.
- Load Object ... the following file /Downloads/MetaKernel2.30/Disk/Install/RECV.KER
- Hit [EVAL]
- WAIT for the installation to finish. It will reboot the calculator automatically at the end.
- Install any library on port 0 after the completion of this procedure.
THEN Error:
Too Few Arguments
