OK, you've got your old 17b or 17bii you use for all your financial needs, but now you need something to do number base conversions. There is no need to go to a scientific model, the solver is your friend.
B1 = old base (2-10)
B2 = new base (2-10)
N = number to convert
ANS = solve for this
Either B1 or B2 must be 10.
BC:ANS=\(\Sigma\)(I:0:LOG(N)\(\div\)LOG(B2):1:MOD(N:B2)\(\times\)B1I+0\(\times\)L(N:IDIV(N:B2)))
(06-18-2014 06:53 PM)Don Shepherd Wrote: [ -> ]BC:ANS=\(\Sigma\)(I:0:LOG(N)\(\div\)LOG(B2):1:MOD(N:B2)\(\times\)B1I+0\(\times\)L(N:IDIV(N:B2)))
Very cool! Thanks for consistently bringing up this calculator.
You don't need
MOD if you combine the calculations from successive lines.
Example: DEC → OCT
+ 2 * 251
+ 20 * 31
+ 200 * 3
3736
BC:ANS=
0\(\times\)L(K:FROM-TO)
+N
+\(\Sigma\)(I:1:LOG(N)\(\div\)LOG(TO):1:
G(K)\(\times\)L(N:IDIV(N:TO))
+0\(\times\)L(K:FROM\(\times\)G(K))
Kind regards
A little shorter:
BC:ANS=
N+
(FROM-TO)\(\times\)
\(\Sigma\)(I:0:LOG(N)\(\div\)LOG(TO):1:
L(N:IDIV(N:TO))\(\times\)FROM^I
(06-19-2014 09:06 AM)Thomas Klemm Wrote: [ -> ]A little shorter:
BC:ANS=
N+
(FROM-TO)\(\times\)
Thomas, that is way cool! Thanks.
The method I chose was based on how I learned to manually convert numbers from one base to another back in computer programming school in 1968. That method is described at the bottom of
this page. I just converted those manual steps to an equivalent solver equation.
I like your method also, it is simple and elegant.
Don
(06-18-2014 06:53 PM)Don Shepherd Wrote: [ -> ]Either B1 or B2 must be 10.
You could set either B1 or B2 to 100. This allows conversions between HEX and DEC.
Example: CAFE
HEX
B1: 16
B2: 100
N: 12101514
ANS: 51,966
(06-19-2014 02:06 PM)Thomas Klemm Wrote: [ -> ] (06-18-2014 06:53 PM)Don Shepherd Wrote: [ -> ]Either B1 or B2 must be 10.
Example: CAFEHEX
B1: 16
B2: 100
N: 12101514
ANS: 51,966
I am stunned! I never thought that was possible. You are a true missle-man.
Here's a program for the HP-12C:
01 - 36 ENTER
02 - 36 ENTER
03 - 45 15 RCL FV
04 - 10 ÷
05 - 43 25 INTG
06 - 43 13 CFo
07 - 45 15 RCL FV
08 - 10 ÷
09 - 43 25 INTG
10 - 43 35 x=0
11 - 43,33 14 GTO 14
12 - 43 14 CFj
13 - 43,33 07 GTO 07
14 - 33 R↓
15 - 1 1
16 - 45 14 RCL PMT
17 - 22 1/x
18 - 24 Δ%
19 - 44 12 STO i
20 - 33 R↓
21 - 33 R↓
22 - 42 13 NPV
23 - 45 14 RCL PMT
24 - 45 15 RCL FV
25 - 30 −
26 - 20 ×
27 - 40 +
Example: 2014
10 → 3736
8
10 STO PMT
8 STO FV
2014 R/S
(06-21-2014 10:18 PM)Thomas Klemm Wrote: [ -> ]Here's a program for the HP-12C:
01 - 36 ENTER
02 - 36 ENTER
03 - 45 15 RCL FV
04 - 10 ÷
05 - 43 25 INTG
06 - 43 13 CFo
07 - 45 15 RCL FV
08 - 10 ÷
09 - 43 25 INTG
10 - 43 35 x=0
12 - 43 14 CFj
14 - 33 R↓
15 - 1 1
16 - 45 14 RCL PMT
17 - 22 1/x
18 - 24 Δ%
19 - 44 12 STO i
20 - 33 R↓
21 - 33 R↓
22 - 42 13 NPV
23 - 45 14 RCL PMT
24 - 45 15 RCL FV
25 - 30 −
26 - 20 ×
27 - 40 +
Example: 201410 → 37368
10 STO PMT
8 STO FV
2014 R/S
That is just amazing, Thomas. I'm sure the creators of NPV and delta-percent on the 12c never envisioned those functions being used for number base conversions.
I tip my hat to you, you are "da man".
But then I realized that the
1:1 translation of my HP-11C program was shorter. And it uses only 3 registers. However it was fun to figure it out.
Addendum:
As long as the from-base
PMT doesn't change the following lines could be removed:
16 - 45 14 RCL PMT
17 - 22 1/x
18 - 24 Δ%
19 - 44 12 STO i
20 - 33 R↓
21 - 33 R↓
With this we are at the same number of lines.
Of course you still have to calculate
i once and store it.
(06-21-2014 11:27 PM)Don Shepherd Wrote: [ -> ]That is just amazing, Thomas. I'm sure the creators of NPV and delta-percent on the 12c never envisioned those functions being used for number base conversions.
I've seen this trick in Valentin's paper: HP-12C’s Serendipitous Solver
