Hi guys! I'm new to HP computers & calculators and will soon be a proud owner of a HP 87xm.
I have also a CP/M cartridge and a thinkjet printer along with the HPIB cable. I was wondering if someone could help me out as I am looking for more information on a GPIB / HPIB disk emulator for the HP 87xm so I can use my CP/M cartridge - where would I be able to buy one? Any tips on how to get it set up with disk images?
Thanks!
I have one of the HP85Disk units, and I love it.
I can also report that it works well with the CP/M cartridge, if you have the required boot disk image.
smp
(03-30-2021 04:30 PM)smp Wrote: [ -> ]I have one of the HP85Disk units, and I love it.
smp
Speaking of disc images, Everett Kaser's HP-85/85B/87 emulator contains a good-sized library of images.
https://www.kaser.com/hp85.html
There's also a disk emulator using an SD card that I first found out about via an article in Elektor magazine
https://www.elektormagazine.com/labs/hpd...-computers
The author of the board has more details on his site and also sells the bare board plus an RTC add-on board, both priced in Euro.
http://www.dalton.ax/hpdisk/
I'm not a big fan of the TQFP package used, since it's difficult to solder by hand. I can't really tell if this is the same as the aforementioned HP85Disk unit - don't think so.
(03-30-2021 06:55 PM)mfleming Wrote: [ -> ]I can't really tell if this is the same as the aforementioned HP85Disk unit - don't think so.
No, that's the emulator by Anders Gustafsson. It's referenced in the HP85Disk documentation.
https://github.com/magore/hp85disk
The HP85Disk and its SD card makes it real easy to download the disk images from the net and make them available for your 85 or 87 without needing to find old equipment capable of writing floppy disks.
(03-30-2021 11:21 PM)cruff Wrote: [ -> ]The HP85Disk and its SD card makes it real easy to download the disk images from the net and make them available for your 85 or 87 without needing to find old equipment capable of writing floppy disks.
And I bet it's a lot quieter too!
If you have a PC with PCI or even ISA slots, there is also the HPDRIVE software emulator by Ansgar Kückes. This software solution requires a HP-IB card and no additional specific hardware.
It can also be used with a small PC (ThinClient) with Windows 98, XP, 2000 as long as it has a PCI slot. See
https://www.hp9845.net/9845/projects/hpdrive/.
Martin
Awesome project! Awesome work by these three as well. Now where is that "Shut up and take my money!" meme?
