What is the product number of the 9114A Disc Drive 'Charger Module' which I should be using here in the UK (220-240V AC)?
I've several different HP calc/accessory charger modules lying around but which is the correct one for the Disc Drive?
Thanks. John S
From the technical manual.
The adapter/rechargers listed next are recommended for use with the HP 88014A Rechargeable Battery Pack.
Model, AC Voltage, Identification
HP 82059B, 90 to 120, United States
HP 82066B, 210 to 250, Europe
HP 82067B, 210 to 250, United Kingdom
HP 82067B Opt 001, 210 to 250, United Kingdom
HP 82068B, 210 to 250, Republic of South Africa
HP 82069B, 90 to 120, Europe
Hi Dave,
Many thanks for confirming HP 82067B recharger details. The HP 9114A has been dormant for 15 years so will probably require a new rechargeable battery before it fires up!
Thanks, John S
(03-29-2021 10:08 PM)Dave Frederickson Wrote: [ -> ]From the technical manual.
