03-20-2021, 01:52 PM
I have slightly changed Free42 code to make the custom menu the system base menu. For DM42 that behavior makes sense as DM42 has dedicated custom keys - for me this change greatly increases usability of the DM42.
The new behavior:
Attached is the zip file with the source code patch and precompiled new firmware.
As usual, use it at your own risk, see LICENSE and COPYING files
@Thomas - would be great to know if there is a more elegant way to get the same behavior. Actually, in my opinion, Free42 itself would benefit from dedicated custom menu keys (I know it can be "skinned", but I mean as the default).
Update 1: Fixed "SHOW" bug - new zip file DM42-3.17-2.5.20p2.zip attached.
Update 2: Fixed an issue with briefly displaying garbage text when pressing EXIT. New zip file DM42-3.17-2.5.20p3.zip attached.
Update 3: Switched to the new DM42 version 3.18 beta 1 (free42 v3.0.1 + bug fix in complexpool logic)
Update 4: For latest version please visit https://github.com/ljubo106/DM42pcm
Note: Firmwares below are neither provided by nor supported by SwissMicros!
-Ljubo
The new behavior:
- Custom menu is the base menu - custom commands are always directly accessible
- Shift is temporary switching to the "upper" custom menu - those commands are just an additional click away
- Shift-CUSTOM activates default DM42 F-Button functionality
- In the Prgm mode Exit will exit custom menu - makes easy to access up and down arrows
- Entering other menus will of course exit Custom menu
-Ljubo
