Full Version: hpgcc2 loop problem
I use HPGCC2 and this tutorial to make sum program for 50g.
http://sense.net/~egan/hpgcc/
example, This sum program made in UserRPL looks like this
<< -> n
<< 0. 1. n FOR X X + NEXT
It's simple program, which gets stack 1 number and calculate 1 to that number sum.
so, I want to C's speed. I coded this.
#include <hpgcc49.h>
int main(void)
    // sum 1 to n and counter i
    int n, i;
    int sum = 0;
    // fast mode
    sys_slowOff();
    // get stack 1 real number
    n = sat_pop_real();
    // calculate sum
    for (i = 1; i <= n; i++) {
        sum += i;
    // output
    sat_push_real(sum);
    sys_slowOn();
    return(0);
and based on top tutorial, I made UserRPL wrapper.
<< "Input 1 real" -> n
<< DEPTH IF 0 == THEN u DOERR END 3: "EXTEND/SM" EVAL
where "EXTEND/SM" is C program's location.
But I execute this program to calculate 1 to 1000 sum, It gives 499500 instead of 500500. and number goes up over 1000, It gives wrong answer.
ex)
input -> answer
999 -> 499,500 (correct)
1,000 -> 499,500 (incorrect which is 500,500)
1,001 -> 500,500 (incorrect which is 501,501)
2,000 -> 1,999,000 (incorrect which is 2,001,000)
10,000,000 -> -2,001,260,032 (I think it is overflow)
I'm a very noob for C, so my code may be wrong. What's wrong with my program?
From quick testing here, your C code appears to be mostly correct. As you suspected, you're seeing overflows in your output for certain large inputs.
I can't tell what your HP code is doing though, as I've never tried compiling stuff under hpgcc and executing it from the calculator.
This is the C code I used to test that things work, at least on a Linux machine (and probably a Microsoft setup too):
#include <stdio.h>
#include <stdlib.h>
int main(int argc, char **argv) {
  int n, i;
  /* Need a bigger value for results above 2e9. May not work for hpgcc2, in this case remove unsigned keyword */
  unsigned long long sum=0;
  /* Some arg checking first */
  if (argc < 2) {
    printf("Cannot run with nothing\n");
    exit(1);
  if (argc > 2) {
    printf("Too many args; I only need one number.\n");
    exit(1);
  /* Absolutely no checking that argv[1] is an int */
  n = atoi(argv[1]);
  for (i=1; i<=n; i++) {
    sum += i;
  /* printf need %lld because of the unsigned long long value we're printing
      You're putting value back on the stack, so calculator will deal with printing instead */
  printf("%lld\n", sum);
  exit(0);
(Post 336)
(03-13-2021 06:41 AM)BINUBALL Wrote: [ -> ]I use HPGCC2 and this tutorial to make sum program for 50g.
<< -> n
int main(void)
    int n, i;
    int sum = 0;
    // fast mode
    sys_slowOff();
    n = sat_pop_real();
    // calculate sum
        sum += i;
    // output
    sat_push_real(sum);
    sys_slowOn();
    return(0);
ex)
input -> answer
Just a WAG (wild-ass guess) but could it be that you're putting a real on the stack while your routine expects an integer?
(03-15-2021 10:14 AM)brickviking Wrote: [ -> ]From quick testing here, your C code appears to be correct. I can't tell what your HP code is doing though, as I've never tried compiling stuff under hpgcc and executing it from the calculator.
This is the C code I used to test that things worked:
#include <stdio.h>
#include <stdlib.h>
  int n, i, sum=0;
  if (argc < 2) {
    exit(1);
  if (argc > 2) {
    exit(1);
  n = atoi(argv[1]);
    sum += i;
  printf("%d\n", sum);
  exit(0);
(Post 336)
I've tried with online C editor too and I confirmed there is no error. Program runs well.
(03-15-2021 10:22 AM)toml_12953 Wrote: [ -> ]
<< -> n
int main(void)
    int n, i;
    int sum = 0;
    // fast mode
    sys_slowOff();
    n = sat_pop_real();
    // calculate sum
        sum += i;
    // output
    sat_push_real(sum);
    sys_slowOn();
    return(0);
ex)
input -> answer
That's a good guess. But I tried with integer 100, it gives 100 0. , therefore it doesn't compute sum.
Can you try to just pop/push and see if the input and output are the same? I agree it may be a float/int thing.
Also for int use n = sat_pop_zint_llong();
Try that.
(03-15-2021 05:55 PM)Egan Ford Wrote: [ -> ]Can you try to just pop/push and see if the input and output are the same? I agree it may be a float/int thing.
Try that.
int main(void)
    int n;
    n = sat_pop_real();
    // output
    sat_push_real(n);
    return(0);
I wrote that code and bug happens too. 1000 -> 999, 1001 -> 1000..
Then what I have to use instead of sat_push_real()?
sat_push_zint()?
sat_push_zint_llong()?
And, where can I find hpgcc2 functions?
Did you try to format sum and n as a long integer?
First thing you should try is to use hpgcc3 instead of hpgcc 2.0. It has several additional years of bug-fixing and a much more polished API to create/pop/push objects to the stack.
It works properly with zint, thank you for everyone.
And, here is my last source code.
int main(void)
    int n, i;
    int sum = 0;
    // fast mode
    sys_slowOff();
    // get stack 1 zint
    // calculate sum
        sum += i;
    // output
    sat_push_zint_llong(sum);
    sys_slowOn();
    return(0);
(03-16-2021 03:34 AM)BINUBALL Wrote: [ -> ]And, where can I find hpgcc2 functions?
Try here:
https://web.archive.org/web/200904100244...hpgcc.org/
(03-16-2021 04:20 PM)Claudio L. Wrote: [ -> ]First thing you should try is to use hpgcc3 instead of hpgcc 2.0. It has several additional years of bug-fixing and a much more polished API to create/pop/push objects to the stack.
Does hpgcc3 still require a custom ROM?
(03-18-2021 05:02 PM)Egan Ford Wrote: [ -> ]Does hpgcc3 still require a custom ROM?
Yes, which is no big deal at all (never was).
The OP posted a few things about newRPL, so I don't think he's nervous about running custom ROMS (if he trusted me to completely replace his firmware, what could go wrong with a couple tiny hacks...).
(03-19-2021 02:51 PM)Claudio L. Wrote: [ -> ]
Does HPGCC3 completely replace stock rom like newRPL? And can I go back stock rom whenever I want?
Trying HPGCC3 may not be bad for me.
