02-17-2021, 09:26 PM
This group of programs compute the Gaussian binomial coefficients and the q-Stirling numbers which are closely related.
The first four programs return triangles as lists of lists. For each program, the integer on level 2 is the number of rows to return(*). The number on level 1 is the parameter q as described in the Wikipedia link. q is normally an integer but these programs will also accept real, complex or rational (e.g. '1/2') numbers.
(*) By convention, binomial coefficients start with row 0 while Stirling numbers usually start with row 1. Therefor the Stirling programs will return n rows while the binomial programs return n+1 rows (0 through n).
The next four programs implement integer transforms based on the above triangles. These are the q-analogs of the binomial, inverse binomial, Stirling S2 and Stirling S1 transforms respectively. Level 2 should have a list of numbers, and level 1 should have the parameter q as above.
For the programs listed above, if q = 1, the "standard" triangles will be returned (Pascal's triangle, it's inverse, the Stirling numbers of the 2nd kind and the Stirling numbers of the 1st kind respectively.)
The last program takes the integers n and k, and the parameter q and returns the individual Gaussian binomial coefficient [n, k]q. As above q can be any numeric type and also symbolic (e.g. 'x'), but cannot be either 1 or -1.
Some of the programs require the ListExt Library. The programs are being posted as a directory for convenience but no program is dependent on any others and unwanted programs can be removed to save space.
DIR
GBTRI
\<< SWAP I\->R \-> q n
\<< { 1 } 1 OVER + 1 2 n
START DUP q * EVAL
NEXT n \->LIST 2. n
FOR k DUP2 1. k SUB * 0 + PICK3 0 SWAP + 2.
\<< + EVAL
\>> DOLIST SWAP
NEXT DROP n 1 + \->LIST
IGBTRI
\<< 1 \-> n q m
\<< { 1 } -1 OVER + 2 n
START m q * EVAL 'm' STO 0 OVER + 2.
\<< m * - EVAL
\>> DOSUBS 1 +
NEXT n 1 + \->LIST
QS2TRI
\<< SWAP I\->R 1. - \-> q n
START DUP q * EVAL
NEXT n \->LIST { + EVAL } LSCAN 2. n
\<< + EVAL
\>> DOLIST SWAP
NEXT DROP n 1. + \->LIST
QS1TRI
\<< 1 \-> n q m
\<< { 1 } -1 OVER + 3 n
START m q * 1 + EVAL 'm' STO 0 OVER + 2.
\<< m * - EVAL
\>> DOSUBS 1 +
NEXT n \->LIST
GBXF
\<< OVER SIZE \-> b q n
\<< b 1. 2. SUB EVAL OVER + 1 2. n
START DUP q * EVAL
NEXT n \->LIST { 1 1 } 3. n
FOR k OVER 1. k 1 - SUB OVER * 0 + 0 ROT + 2.
\<< + EVAL
\>> DOLIST b 1. k SUB OVER * \GSLIST EVAL UNROT
NEXT DROP2 n \->LIST
IGBXF
\<< OVER SIZE 1 \-> q n m
\<< DUP 1. 2. SUB EVAL OVER - ROT { -1 1 } 3. n
FOR k m q * EVAL 'm' STO 0 SWAP + 2.
\<< m * - EVAL
\>> DOSUBS 1 + OVER 1. k SUB OVER * \GSLIST EVAL UNROT
QS2XF
\<< b 1. 2. SUB EVAL OVER + 1 2 n
START DUP q * EVAL
NEXT n \->LIST { + EVAL } LSCAN { 1 1 } 3. n
\<< + EVAL
QS1XF
\<< OVER SIZE 1 \-> a q n m
\<< a 1. 2. SUB EVAL OVER - { -1 1 } 3. n
FOR k m q * 1 + EVAL 'm' STO 0 SWAP + 2.
\<< m * - EVAL
\>> DOSUBS 1 + a 1. k SUB OVER * \GSLIST EVAL SWAP
NEXT DROP n \->LIST
GBC
\<< PICK3 I\->R PICK3 I\->R DUP2 SAME OVER 0. SAME OR NOT
{ DUP2 2. * <
{ - R\->I 2. UNPICK }
{ DROP2 } IFTE \-> n k q
\<< 1 q n -1 k LASEQ ^ - LPROD 1 q k LSEQ ^ - LPROD / EVAL
{ 5. DROPN 1 } IFTE
END
