02-08-2021, 05:35 AM
Casio fx-991EX manual didn't give example on the use case for the Inverse of the Matrix while
HP-15C User's Handbook gave the example problem for the Inverse Matrix and Multiplication of Matrix to use for the Linear Equation of Unkonws Varibles.
I'll use 15C User's Handbook Example on Page 156 "Title Soving the Equation AX=B"
AX=B equation can be changed to X = A^-1 x B
Example Matrix Equation: On page 157
Here is the steps on how to enter "Matrix Calculations" using Casio fx-991EX with Matrix Mode
[MENU] [4] // Matrix Mode //
[1] // Matrix A //
[2] [2] // Set Matrix A to 2x2 //
[1] [=] [1] [=]
[.24] [=] [.86] [=]
[OPTN] [1] [2] // Define Matrix and Matrix B //
[2] [3] // Set Matrix B to 2x3
[274] [=] [233] [=] [331] [=]
[120.32] [=] [112.96] [=] [151.36] [=]
[OPTN] [3] // Matrix Calculation //
[OPTN] [3] // Seclect Mat A //
Screen Display MatA enter [X^-1] [x] [OPTN] [4]
Screen Display MatA^-1 x MatB press [=]
Screen Shown Answer:
MatAns= 186, 141, 215, 88, 92 and 116
Remark:
A system of Linear Equation can be solve by using the [MENU] mode A seclection #1: Simul Equation
for the restriction that constant matrix and solution matrix each had one column.
While the example shown above is for a constant matrix and solution matrix with more than one column.
Gamo 2/2021
[1] // Matrix A //
[1] [=] [1] [=]
[.24] [=] [.86] [=]
Remark:
Gamo 2/2021
