02-05-2021, 10:02 PM
Colebrook Equation
[attachment=9074]
I read that an iteration of the Colebrook Equation will test the values of 'f' that will result in the difference between the two sides to be zero or very close to zero. Also, generally three to four iterations are sufficient to converge on a reasonably good value of the friction factor. How was this conclusion reached? I've never worked with iterations before. Will a Do-While loop work well?
[attachment=9074]
