Can you tell me how I can edit my program/App to start with the Num view.
I tried startview but is not working
START()
msgbox("VOL")
//Symb—change to Num
Symb()
startview(2,0)
//Plot—disable
Plot
//PlotSetup—disable
PlotSetup()
END
One of the many ways available on the HP Prime is to initialize your application in the START() BEGIN ... END; code block :
Edit the initial code generated when you save the built-in SOLVE application into your SolveVOL application. If needed, scratch your SolveVOL app. and restart from beginnning.
Then press [shift] [ Program] and select 'SolveVOL(App)' and touche ( EDIT ) to modify your code application so it contains at least this :
START() // This section of code executed every time you select your SolveVOL application
'L*W*H=V'▶E1; // This enter your volume equation in equation slot n°1
CHECK(1); // This activate the equation slot n°1
STARTVIEW(2,0) // This start the application with the view #2 which is the same as on [ NUM ] key
You can leave all the comments in place as a reminder of the different available sub-sections.
You just have to remove comment delimiters // in the START() section of the code and type the few needed.
Hope this help...
Regards.
C.Ret[/code]
