Can you tell me if is possible to do a program on the prime for the volume formula ( L*H*W=V) or I need to input it all the time on the solver.
In Free42 I did this program.
00 { 31-Byte Prgm }
01▸LBL "VOL"
02 MVAR "V"
03 MVAR "W"
04 MVAR "L"
05 MVAR "H"
06 RCL "W"
07 RCL× "L"
08 RCL× "H"
09 RCL- "V"
10 END
HI,
You don't even need to program anything.
Press the [ Apps ] button and scroll the screen down to touch the SOLVE application icon.
Select for example the E1 equation slot and press screen bottom ( Edit ) to enter your equation directly: W*H*L=V press [ ENTER ]
To solve for a problem, press [ Num ] button and you are in what is the closest thing on HP prime to a solver menu in the HP-42's style.
You can leave your equation in this slot forever.
To secure it, you can save it with a spécific name; select the SOLVE application icon and touch the bottom screen ( Save ). Edit the name, this create a dedicated application icon with all your equations save in it .
Yes I was starting to think that a program was not needed.
By saving you telling to copy the solver app ?
(01-13-2021 07:14 PM)C.Ret Wrote: [ -> ]HI,
Select for example E. equation slot and press screen bottom ( Edit ) to enter your equation directly: W*H*L=V press [ ENTER ]
To solve for a problem, press [ Num ] button and you are in what is the closest thing on HP prime to solver menu of HP-42s
By security you can save it; selection the SOLVE application icon and touch the bottom screen ( Save ). Edit the name, this create a dedicated application icon with all equation save in it .
(01-13-2021 07:19 PM)fs5qc Wrote: [ -> ]By saving you telling to copy the solver app ?
Yes, that the way HP Prime made it. It optional, depending on how you use your calculator.
Personally, having no more regular professional use of it, I never save any application, I weekly use the connectivity kit to archive programs and data.
