01-11-2021, 12:57 AM
After buying my 35s and realizing how much there was to learn and not being able to expeditiously find the keys mentioned in the User Manual the need for a file that let me look up the key was apparent. The attached file is based on the Keyboard figure in the User manual but, being electronic media, is searchable.
The attached file is open source and is available without reservation as my intent is to share my solution to a vexing issue; to wit, learning a complicated subject without knowing where the subject matter material is readily accessible.
Short story is that my eyes are not what they used to be and so hopefully this file helps others overcome similar difficulties.
Thank you. Respectfully, Daniel
P.S.-Editing and other suggestions will be greatly appreciated.
“May your choices reflect your hopes, not your fears.” - Nelson Mandela
