This was a program my father wrote, it appears to be a flight planning application. I could use some help deciphering it. It does run. Run size and set to 100 to fully load the program
2022/02/19
corrected the original program and attached it to this post
Sounds like a project for Geoff Quickfall
I wasn't sure if it belonged in the software library as it lacks documentation. Any help in deciphering what is going on is greatly appreciated
(12-15-2020 06:06 AM)WrongWay Wrote: [ -> ]This was a program my father wrote, it appears to be a flight planning application. I could use some help deciphering it. It does run. Run size and set to 100 to fully load the program
In line 16 there's a GT0 CF but LBL "CF" is nowhere to be found. Is this a typo??
GTO C doesn't look likely either given where the instruction is: no previous test and no LBL after it.
Would be good if you can double check the listing...
X=0?
GTO 00
SF 03
GTO CF
FS? 00
GTO 01
LBL 00
There is also a REGMOVE command, this code may need the XFunctions module ?
(05-13-2021 07:13 AM)Ángel Martin Wrote: [ -> ] (12-15-2020 06:06 AM)WrongWay Wrote: [ -> ]This was a program my father wrote, it appears to be a flight planning application. I could use some help deciphering it. It does run. Run size and set to 100 to fully load the program
X=0?
GTO 00
SF 03
GTO CF
FS? 00
GTO 01
LBL 00
It looks like the CF flag is being used for indirection
Ie if CF= 03 GTO CF > GTO LBL 03
(05-20-2021 09:59 AM)Stevetuc Wrote: [ -> ]It looks like the CF flag is being used for indirection
I don't think so; if this was the case when are the instructions that follow executed?
(05-21-2021 05:21 AM)Ángel Martin Wrote: [ -> ] (05-20-2021 09:59 AM)Stevetuc Wrote: [ -> ]It looks like the CF flag is being used for indirection
Is it a clever synthetic though? couldn’t you use the first (top) 10 keys as surrogates for 00-10 in STO and RCL and GTO?
I think a piece of the program is missing though, there aren’t routines sensitive to flag 03?
Todd
(05-22-2021 01:11 AM)twdeckard Wrote: [ -> ]couldn’t you use the first (top) 10 keys as surrogates for 00-10 in STO and RCL and GTO?
Yes, but 01-10.
There might have been a typo at my hand. I will rescan the tapes and see if I can transcribe them better. I've seen mention of some USB hardware that might be of use but no idea what i need to do to make that a reality
X=0?
GTO 00
SF 03
GTO CF
FS? 00
GTO 01
LBL 00
Yes, this should be GTO "C"
I tried compiling this program and I can't seem to get it to run on V41, it gets to STO 50 and returns NONEXISTANT. How is it possible?
Answer: It requires Synthetic Programming
Wrong way, did you pull the program down? could you repost it?
Best
Todd
Best
Todd
(02-20-2022 05:06 AM)WrongWay Wrote: [ -> ]I tried compiling this program and I can't seem to get it to run on V41, it gets to STO 50 and returns NONEXISTANT. How is it possible?
Are you sure you were using the correct SIZE parameter ?
Great question! I am not sure I am using the correct size parameter. This code was found in a box of magnetic strips and there is no documentation about it anywhere.
JETLOG program attached. for some reason I can't attache raw files, but the zip file contains the raw
The size appears to be 176.
(02-20-2022 12:15 AM)WrongWay Wrote: [ -> ] (05-13-2021 07:13 AM)Ángel Martin Wrote: [ -> ]In line 16 there's a GT0 CF but LBL "CF" is nowhere to be found. Is this a typo??
X=0?
GTO 00
SF 03
GTO CF
FS? 00
GTO 01
LBL 00
I wouldn't think so, that would mean that the following two program steps are never executed:
SF 03
GTO "C"
FS? 00
GTO 01
LBL 00
It's probably more likely to be this, changing SF 03 with FS? 03:
FS? 03
GTO C
FS? 00
GTO 01
LBL 00
right?
