I'm going over some simple math problems on both my HP50G and my Prime.
When I try to solve the very simple equation
(x-3)^(2/3) = 4
The HP50G correctly provides 11 and -5 as answers within a list
However the Prime only finds 11 as root, also within a list.
What gives?
Thanks for reading.
Try using surd for the 1/3 power.
Cas> solve((surd(x-3,3)^2) = 4,x) → {-5,11}
(12-13-2020 01:38 AM)Albert Chan Wrote: [ -> ]Try using surd for the 1/3 power.
Thanks!!! It worked.
However, I still would like to know what's behind the difference between how the 50G and the how the Prime find the roots.
(12-13-2020 02:52 AM)rrpalma Wrote: [ -> ]Thanks!!! It worked.
By using the fractional exponent "1/3" the Prime returns the principal cube root, which in this case will be a complex number for any x<3. Whereas using surd or NTHROOT it returns the real-valued root instead, allowing for a zero at x=-5 in the equation (x-3)^(2/3)-4=0.
Edit: Wolfram Alpha for reference:
https://www.wolframalpha.com/input/?i=%2...3%29-4%3D0
If you want to assume the real-valued root on the Prime, always use the root template key, nthroot, or equivalent.
(12-13-2020 03:45 AM)victorvbc Wrote: [ -> ] (12-13-2020 02:52 AM)rrpalma Wrote: [ -> ]Thanks!!! It worked.
Edit: Wolfram Alpha for reference: https://www.wolframalpha.com/input/?i=%2...3%29-4%3D0
Thanks. Very much appreciated. I tried it both with NTHROOT and the template, and it worked. I'm still confused on why HP50G directly provides the real-valued root(s) whereas the Prime doesn't. I guess that's the way it is, and that's it. Or, how do I force then the HP50G to provide only the principal root?
(12-13-2020 04:33 AM)rrpalma Wrote: [ -> ]Or, how do I force then the HP50G to provide only the principal root?
I had thought that setting system flag -1 "principal value" might do it; but no, not with SOLVE.
Whereas if you use ISOL (isolate), it does honour the flag, but shows X=-5 only
(12-16-2020 02:12 AM)cdmackay Wrote: [ -> ] (12-13-2020 04:33 AM)rrpalma Wrote: [ -> ]Or, how do I force then the HP50G to provide only the principal root?
Thanks!! That's really odd :-)
