The chance of hitting half-way cases are small.
We can do the remainder check by then. This made the code simpler too.
PHP Code:
function idiv6c(a, b) -- assumed b > 0
local r = a/b
local q = floor(r)
if q ~= r then return q end
r = (a%b) * 2
if r == b then r = a % (b+b) end
return r > b and q-1 or q
end
Example, for 2-digit calculator, above/below halfway decides how to correct q
a/b = 700/22 = 31.81..., rounded to q = 32
ulp = (a%b)/b = 18/22 ≈ 0.81 ULP, above halfway, return q-1 = 31
a/b = 700/23 = 30.43..., rounded to q = 30
ulp = (a%b)/b = 10/23 ≈ 0.43 ULP, below halfway, return q = 30
For halfway case, r is updated, r = a % (b+b)
Previously, r = b, this implied updated r = b/2, or 3b/2
To maintain even q, and remainder range of ±b, 3b/2 got shifted down 2b, to -b/2
Only -b/2 remainder require correction: a/b = q - 1/2, rounded-up to q, floor-divide should be q-1
a/b = 460/40 = 11.5, rounded to q = 12 (half-way to even)
r = (a%b)*2 = 40 = b --> signal halfway case
r = a%(b+b) = 60 --> signal remainder = -20, floor-divide should return q-1 = 11
Reuse the code for non-halfway: return r > b and q-1 or q
For above example, r=60, b=40, thus it return q-1 = 11, as expected
Update: removed variable h=b/2. This made the code more robust.
Previously, we had r = a%b, followed by r = a%(b+b) if halfway.
Last line was return r > h and q-1 or q
For halfway case, we may hit with *slight* floor-mod rounding.
If a is negative, a % (b+b) = (b+b) - |a| % (b+b) = 4h - 3h = h
But, 3h term might not be exact, thus last h may have *slight* rounding error.
Update 2: fix a typo for halfway test, r == 0 should be r == b
