Quadratic interpolation is simply 2 linear interpolations, followed by linear interpolation.
x3 y3
x2 y2 y23
x1 y1 y13 y123
Similarly, cubic interpolation is 2 quadratic interpolations, followed by linear interpolation.
x4 y4
x3 y3
x2 y2 y234
x1 y1 y134 y1234
Using this recursive nature of polynomial interpolation, I get this neat Lua code
function interp(x1,y1,x2,y2,x3,y3,x4,y4) -- estimate y = p(0)
if x3 then
y2 = interp(x2,y2,x3,y3,x4,y4)
y1 = interp(x1,y1,x3,y3,x4,y4)
end
local y, p = y2, x2/(x2-x1)
if p > 0.5 then y, p = y1, x1/(x2-x1) end
return y - p*(y2-y1)
end
Extending interp(...) is trivial, by adding (x5,y5), ...
The down-side is each bump up in polynomial degree, doubled the work.
For high degree fit, divided-difference style is better, because it can cache previous results.
OTTH, assuming we have convergence, old points are very, very far away.
Fitting those probably may not help much ...
For slope of improved secant, we can also consider this an interpolation problem.
Example, for a cubic fit, we generate divided-difference table:
x4 y4
x3 y3 y34
x2 y2 y24 y234
x1 y1 y14 y123 y1234
p(x) = y4 + (x-x4)*(y34 + (x-x3)*(y234 + (x-x2)*y1234)) = y4 + (x-x4)*M
p'(x) = M + (x-x4)*M' → p'(x4) = M
Basing all values relative to (x4, y4). Example X3 = x3-x4, Y3 = y3-y4 ...
M is just interpolation of individual slopes.
X3 Y3/X3
X2 Y2/X2
X1 Y1/X1 M
Again, extending this is simply adding more slopes to fit
function secant(x1,y1,x2,y2,x3,y3,x4,y4) -- estimate root of p(x)
if not x3 then return interp(y1,x1,y2,x2) end
if x4 then x3,y3,x4,y4 = x4,y4,x3-x4,(y3-y4)/(x3-x4) end
x1, y1, x2, y2 = x1-x3, y1-y3, x2-x3, y2-y3
return x3 - y3 / interp(x1,y1/x1, x2,y2/x2, x4,y4)
end
Example:
lua> function f(x) return sin(x)/x - 1/6.5 end
lua> x1, x2 = 2.711, 2.712
lua> y1, y2 = f(x1), f(x2)
lua> x3 = secant(x1,y1, x2,y2)
lua> y3 = f(x3)
lua> interp(y1,x1, y2,x2, y3,x3) -- inverse interpolate, x = g(0)
2.711312910356982
lua> secant(x1,y1, x2,y2, x3,y3) -- improved secant, x = x3 - y3/slope
2.7113129103569826
