11-29-2020, 12:23 AM
Severe bug:
Calculation results of undef-undef*i itself won't stall the calculator, but,
if you try to PRINT the result containing undef-undef * i,
the calculator will stall and reboot.
In these case, using cat befor PRINT will be a workaround for the problem.
The + operator also seems to have some potential problems.
The version of the Physical HP Prime is:
Another bug in the Emu is that a 0 is added at the begging when printing a string and numbers.
The version of the HP Prime Emu is:
#CAS
print_undef_test():=
LOCAL x, y, z;
LOCAL g, k;
LOCAL s;
g := MAXREAL / 2;
PRINT("print_undef_test:"); // Printing a string is OK.
PRINT("(2 * g + i * g ) / (g + i * k * g), g="+ g);
//There is a bug that a 0 is added at the begging when printing a string and numbers in Emu,
FOR k FROM 0.0 TO 2.0 STEP 0.5 DO
x := 2 + i; y := 1 + i * k;
PRINT("k="+k+":Ref.-> " + (x / y));
//however, printing a string after a number is OK.
z := (x * g) / (y * g);
// Calculation results of undef-undef*i itself won't stall the calculator, but,
// PRINT(k + ":#/# -> "+ z);
// tring to print a result that is undef-undef*i will stall the calculator to reboot.
// s := k + ":#/# -> "+ z;
// Using + operator to a string and undef-undef*i will stall the Emu to reboot,
// but it's OK for Physical HP Prime.
// PRINT(s);
// however, printing the 's' above will stall the calculator to reboot.
// PRINT(z);
// Tring to print only undef-undef*i also stall the calculator to reboot.
PRINT(cat("k=",k,":#/# -> ", z));
// Using cat befor PRINT is a workaround for the problem above.
// The + operator seems to have some potential problems.
return z;
#END
