11-25-2020, 03:29 PM
One of the more handy things to do with a CAS graphing calculator is to copy a result from the main screen and paste it into graphing equation section and then graph it. This does not seem to work on HP Prime.
For example, let's say I differentiate a poly on the CAS command screen and the result is:
3x^2-4x+3
and I want to graph it. So, I use copy and then go to the Symb screen and try to paste it in the F1(X)= spot. It won't paste because it gets a syntax error. It turns out that the x's on the CAS command screen are NOT compatible with the Function Symbolic View screen. Is there any work-around on this bug?
Thanks!
3x^2-4x+3
Thanks!
