This is an RPL version of the HP-42S program
above:
« PUSH RAD -105 CF -3 CF DUP 10 * 21 / 1 + CEIL 0 2 ROT 8 OVER *
PICK3 + UNROT 1
FOR i i DUP + DUP 1 - UNROT * OVER / SWAP SQ 4 ROLL 4 PICK + /
UNROT -1
STEP SQ UNROT 2 / + / EXPAND FXND DUP SIZE R→I ALOG OVER -
PICK3 * SWAP IQUOT + →STR DUP HEAD 0 I→R →STR TAIL + SWAP TAIL
+ 1 ROT 2 + SUB POP
# 8F62h, 258 bytes
51 decimal digits: 10.502 s
85 decimal digits: 32.557 s
153 decimal digits: 160.952 s
357 decimal digits: 4393.037 s
(HP 50g)
PS:
Actually, the RPL program above is based on one of my older formulae. The following program is slower, but it is in accordance with the formula I used in the RPN program:
« PUSH RAD -105 CF -3 CF R→I DUP 12 * 25 / CEIL DUPDUP 8 * 4 + DUP
8 - ROT SQ 4 * 1 - 2 0 UNROT 1 7 ROLL
START OVER 1 + * OVER / UNROT DUP ROT 6 PICK + / UNROT 4 ROLL
SWAP OVER - UNROT 8 - 4 ROLLD
NEXT NIP 2 ROT 5 ROLL + 1 - / 1 + * NIP EXPAND FXND DUP SIZE R→I
ALOG OVER - PICK3 * SWAP IQUOT + →STR DUP HEAD 0 I→R →STR TAIL
+ SWAP TAIL + 1 ROT 2 + SUB POP
# 5CB1h, 301.5 bytes
51 decimal digits: 12.344 s
85 decimal digits: 42.373 s
153 decimal digits: 308.168 s
(HP 50g)
1000 decimal digits: 2988.379 s
(iPhone7, emulated HP 49g+, m48+)
Algorithm:
input digits ; number of decimal digits
n := ceil(12*digits/25)
c := 0
d := 8*n + 4
e := d - 8
m := 4*n*n - 1
w := 2
i := n
repeat
w := w*(m + 1)/m
c := m/(c + d)
m := m - e
e := e - 8
i := i - 1
until i = 0
c := 2/(c + d - 1) + 1
p := c*w
output p
PPS:
This is a longer version of the previous program, but it’s significantly faster for larger numbers of decimal digits (and even faster than the first program). Also, as in the previous program, all decimal digits are correct (actual digits, no roundings).
« PUSH RAD -105 CF -3 CF R→I DUP 12 * 25 / CEIL DUPDUP DUP + 1 +
OVER 8 * 4 + DUP 8 - 0 5 ROLL SQ 4 * 1 - 5 PICK 1 DUP 9 ROLL
START OVER 2 - UNROT OVER 1 - ROT / * PICK3 6 PICK - UNROT 4 ROLL
5 ROLL 7 PICK + / 4 ROLLD 5 ROLL 8 - 5 ROLLD
NEXT SQ 7 ROLL * 4 5 ROLL 7 ROLL + 1 - / 2 + * 4 ROLLD 3 DROPN
EXPAND FXND DUP SIZE R→I ALOG OVER - PICK3 * SWAP IQUOT + →STR
DUP HEAD 0 I→R →STR TAIL + SWAP TAIL + 1 ROT 2 + SUB POP
# E567h, 354 bytes
51 decimal digits: 10.355 s
85 decimal digits: 31.200 s
153 decimal digits: 157.039 s
357 decimal digits: 3820.207 s
(HP 50g)
1000 decimal digits: 2588.102 s
Algorithm:
a := 2*n + 1
b := a
c := 0
d := 8*n + 4
e := d - 8
m := 4*n*n - 1
w := 1
i := n
repeat
w := w*(a - 1)/a
c := m/(c + d)
a := a - 2
m := m - e
e := e - 8
i := i - 1
until i = 0
c := 4/(c + d - 1) + 2
p := b*c*w*w
output p
