11-17-2020, 09:33 PM
Hi guys
I encountered a wired behavior of the HP Prime emulator in the Function App.
With a program named 'cs' in Function App. is invisible, however,
the cursor moves as if it's on the correct plot and the numerical plot is OK.
The formula -- replaced a constant to Y variable -- is OK in the Graph 3D App.
On the phisical HP Prime BS, it shows visible plot -- no problem.
And one other problem is calling a CAS version of the program (LW0C) from Home version of a program crashes on both the emulator and the Physical HP Prime.
What is wrong? usage? or an any kind of bug?
HP Prime Graphing Calculator
Software Version: 2.1.14425 (2020 01 16)
Hardware Version: Emu
CAS Version: 1.5.0
Operating System: Windows 7 SP 1 (6.1)
P.S.
Atteched file is the backup of the Emulator under test.
P.P.S.
Some conditional test results.
1) A home program 'cs' that uses 'LW0' home program is OK in Graph 3D app, however, in Function App. it shows invisible plot but its value at the cursor is OK and the Function Numeric View is OK as well.
2) A home program 'csB' that uses 'LW0C' CAS program crashes in Graph 3D App. and in Function App.
3) A CAS program 'csBW' that uses LW0C CAS program is OK and plots well in both Function App. and Graph 3D App.
4) 'cs' is OK in Function App. and in Graph 3D App. with pysical HP Prime G2.
5) 'csB' is OK in Function App. with pysical HP Prime G2, however, it crashes in Graph 3D App. to show "... had a problem and will reboot in 3 seconds".
6) 'csBW' is OK in Function App. in Graph 3D App. with pysical HP Prime G2.
EXPORT cs(Ir, Tj, Rd)
// cs -- current source
// Ir : reference current
// Tj : junction temperature (in Centigrade)
// Rd : degeneration resistance
LOCAL k, q, Vt;
k := 1.380649e-23; // Boltzmann constant
q := 1.602176634e-19; // elementary charge
Vt := k * (273.15 + Tj) / q; // Thermal voltage
IF Rd == 0 THEN return Ir; END;
return Vt * LW0(Ir * Rd / Vt) / Rd;
//LW0 - Principal branch of the Lambert W function
//Rev.1.40 (Nov. 12, 2020) (c) Takayuki HOSODA (aka Lyuka)
//Acknowledgments: Thanks to Albert Chan for his informative suggestions.
EXPORT LW0(x)
LOCAL y, p, s, t;
LOCAL q, r;
HComplex := 1; // Enable complex result from a real input.
r := 1 / e;
s := simplify(x + r);
IF s == 0 THEN return -1; END;
q := e - sqrt(2) - 1;
y := ln(r + sqrt((r + r) * s) + q * s); // approximation near x=-1/e
r := MAXREAL;
REPEAT
p := y;
q := r;
t := exp(y);
s := y * t;
t := (1 + 0.5 * y) * (s + x) + t;
IF (0 == t) THEN break; END;
y := y - (y + 1) * (s - x) / t; // Halley's method
r := abs(y - p); // correction radius;
UNTIL 0 == r OR q <= r; // convergence check
return p;
CAS Version: 1.5.0
P.S.
P.P.S.
