11-14-2020, 12:16 AM
Hi Everyone,
this an update of an older post, basically this unit has an hybrid pcb and a keyboard/led pcb with this issue :
When used with its own hybrid the display turns on the requested segments for the requested digits PLUS all the decimal points and all the C segments
When used with any other different (known working) hybrid the display turns on the requested segments for the requested digits PLUS the decimal points
and the C segments for the digits actually used plus the one after the last one
I think the pictures will better describe the situation
All of the waveforms have been taken using a known working hybrid logic board
Quite surprising all the waveforms are of the correct form and value
What could it be the problem ?
There are no open coils but we don't know how to test if some coils are shorted together
Unluckily we have not taken the waveform for Anode segment C when it should not be on, like when the display is showing a 2
Thanks in advance for any advice !
Pictures : HP-65 1605A02841 - wrong display behavior
