Hi everyone,
this came out of my high school drawer, and it is quite useful while measuring
values or waveforms from an IC.
We would like to buy bigger and "longer" models, but I can't find them on any shop
I have written to the maker (Cliff) but with no reply,
Does anyone know what's the technical name so that we can narrow the search ?
Thank you so much !
Pictures here :
IC tool
Hi Dave,
with these you need to remove the IC from the PCB
we want to measure with the IC in place on its PCB
(11-12-2020 03:48 PM)Dave Frederickson Wrote: [ -> ]It's a 16-pin DIP Zero Insertion Force (ZIF) socket.
These are from Amazon.
I finished High School in 1983, you can call these "vintage"
Searching IC test clip returned a number of vendor including 3M which is good
thanks for the help
Cliff answered that they no longer produce these ...
(11-12-2020 03:43 PM)mfleming Wrote: [ -> ]It's an IC test clip. I haven't seen one of those in many a moon, no doubt due to the prevalence of surface mount ICs these days. A web search turned up this link
https://www.mouser.com/ProductDetail/Spa...Q9SA%3D%3D
Or from the source
https://www.sparkfun.com/products/13153
Hopefully a similar supplier can be found in your locale.
I have now found some of them at home.
They remind me of the good old days around 1980, when it was a great job to make a system full of multibus cages with dozens of PALs and tons of TTLs.
(Now that kind of system is like a simple coding job that fits into one FPGA)
I would like to buy the 3M model for a 20 pins IC like the anode driver or the cathode driver of a Classic unit
These clips are available in two different widths
Is the 0,3” width the right one ?
Thanks !!!
