11-11-2020, 01:53 AM
11-11-2020, 05:39 AM
FWIW, I use the built-in CRLIB command. It's documented in the 50g AUR manual, Chapter 6, in the section entitled "CRLIB -- Create Library Command" (pages 6-9 through 6-10).
11-11-2020, 08:14 PM
I already have read this post from you, at HP.com.
Thank you!
Thank you!
(11-11-2020 05:39 AM)Joe Horn Wrote: [ -> ]FWIW, I use the built-in CRLIB command. It's documented in the 50g AUR manual, Chapter 6, in the section entitled "CRLIB -- Create Library Command" (pages 6-9 through 6-10).
11-18-2020, 08:47 AM
Maybe I can use L.I.C?
[APPS] [14 L.I.C]
![[Image: lic2.jpg]](http://area48.com/hpm/lic2.jpg)
[APPS] [14 L.I.C]
11-18-2020, 01:52 PM
(11-18-2020 08:47 AM)CMarangon Wrote: [ -> ]Hello!
[APPS] [14 L.I.C]
L.I.C. doesn't create libraries; it creates library installers. Furthermore, L.I.C. is not a built-in feature of the HP 50g; it only appears in the APPS list of the machines in which L.I.C. was installed. See the README.TXT file that comes with it: https://www.hpcalc.org/details/4761
