11-02-2020, 06:28 AM
Sorry if this had been specifically asked before, I searched but couldn't find anything.
Suppose I want to factorize the expression: a*s^(2) + b*s + c for the variable s. In other CAS systems this could be done simply by specifying it inside the factor(expression,var) function, in calculators such as the TI 89, see image attached. I haven't found a way to achieve this on the HP Prime as its factor function doesn't work the same way.
