I have an HP10S.
Well, my doubt is if it works with sun light, because when I put my finger over cell light and cover it all, it does no take any effect.
I have an HP10S.
Does its internal battery work as a back up?
Carlos (BR)
Time zone: GMT -3
Ah, the HP 10s+ (not 10S). Yes, the battery takes over if there's not enough light for the solar panel to produce enough energy to run the calculator.
Congratulations on your acquisition of a Casio in (very thin) disguise.
It almost certainly is a dual-power machine, i.e. both a solar cell and battery. It looks nearly identical to the Casio fx-300MS, which has the same power supply system.
(10-13-2020 01:31 PM)Maximilian Hohmann Wrote: [ -> ]it uses a lithium battery of type LR44 as a backup when there is not enough light to power it.
Huh? The LR44 is an alkaline battery.
The OP says that the calculator does not go out when covering the solar panel, which leads him to believe that there's a battery picking up the slack when needed.
I have an HP10S.
Carlos (BR)
Time zone: GMT -3
