(06-09-2014 02:12 PM)rprosperi Wrote: [ -> ]Thomas - Is there a way to create these individual post# links automagically, or only crafting them by hand (insert thread link then edit to add post#)? Quite useful and elegant way to save space in complex replies.
You can right-click the number of the post in the top right corner,
choose [Copy Link Location] in the context-menu
and then create a link in the toolbar [Insert hyperlink]:
I can't reference only this icon but it's the earth and the chain.
You can even add a
highlight url-parameter:
#19.
PS: In the old forum you had to search for the id of a post in the source in order to directly link to a certain post.
10 points for pointing to this feature.
-10 points for tearing even that little sub-thread to shreds by forgetting to apply that theoretical knowledge.
d:-I
(06-09-2014 02:00 PM)Gerald H Wrote: [ -> ] (06-09-2014 01:54 PM)J-F Garnier Wrote: [ -> ]Can you make sure if by chance one of your machine is in PON (Printer On) mode and this other one in POFF?
Both with same flag settings & printing is off.
Interesting.
To answer your initial question: no, such a variation between versions is not expected/common.
I checked with a simple test program on my A and C machines and got no significant differences, my C machine is even about 5-10% slower than my A, so it doesn't depend on the software version.
Maybe something is wrong in one of your machine regarding system clock, even if the self-test reports 1MHz in both cases.
If you try to do a BEEP on both machines, can you hear a significant higher pitch on one?
For your reference, here is my test program:
LBL "X"
"RUN"
AVIEW
LBL 01
GTO 01
Starting with a stack filled with 1, I get about 520 on my A machine and 490 on my C machine in 10 seconds.
Thomas, now you get -15 points for reasons mentioned
here.
d:-(
Again,
10 points for pointing to that,
but -10 points for lack of application. Compare
there.
Shall I quote Albert E. next?
d:-(
(06-09-2014 03:00 PM)J-F Garnier Wrote: [ -> ] (06-09-2014 02:00 PM)Gerald H Wrote: [ -> ]Both with same flag settings & printing is off.
Interesting.
LBL "X"
"RUN"
AVIEW
LBL 01
GTO 01
Quite amazing - this correspondent actually says something relevant to the topic!
Interesting.
LBL "X"
"RUN"
AVIEW
LBL 01
GTO 01
I've now recovered my composure.
If you could enter the progs under post # 13 & time them? It's a lot to ask so no offence if you shouldn't bother.
A similar request on anyone with version A & C HP 42Ss.
(06-09-2014 04:55 PM)Gerald H Wrote: [ -> ]If you could enter the progs under post # 13 & time them? It's a lot to ask so no offence if you shouldn't bother.
Well, no I won't key in (twice) these rather long programs.
But if you can do on your side my simple test and the BEEP check I mentioned, it could give us a clue.
J-F
(and don't bother about the repetitive OT messages :-)
To post # 29:
Beeps sound similar.
Your short test prog, & similar short loops, show the A version as marginally faster, but this would in no way account for the difference in timing for the factorization in post # 13.
(06-09-2014 05:15 PM)Gerald H Wrote: [ -> ]To post # 29:
Your short test prog, & similar short loops, show the A version as marginally faster...
OK. So we have similar machines (A slightly faster than C). And you have a program that runs faster on one machine. Nice mystery to solve.
And please use the Quote feature rather than a reference to a post in writing... thanks!
J-F
(06-09-2014 03:00 PM)J-F Garnier Wrote: [ -> ]For your reference, here is my test program:
LBL "X"
"RUN"
AVIEW
LBL 01
GTO 01
I tried your test program with my Version C units. I consistently get between 510 and 530. Variation is probably due to my inability to press R/S exactly at the same moment on each run.
Bill
(06-09-2014 04:42 PM)Thomas Klemm Wrote: [ -> ]Gähn
Oooh, that link shows exhausted poor little Thomas passed/past his limits. Don't overstress again. Get well soon!
d;-)
Okay, I have entered your program on a Version C machine. I double & triple checked the code enter to make sure it matches your posted listing. I have printed it out and then checked the printout line by line with your listing. So I'm pretty sure it is entered correctly. Unfortunately, it does not seem to end - I've let it run for over 30 minutes with so solution.
Maybe I'm not initializing the program correctly.
I do the following:
enter 11,111,111,111 into the X register.
enter "seed"
(11,111,111,111 is still in the X register
I then do XEQ "POBR"
It then runs, but doesn't seem to end.
Am I'm doing something wrong? Is there something I should initialize or do?
Bill
(06-09-2014 02:12 PM)rprosperi Wrote: [ -> ] (06-09-2014 01:59 PM)Thomas Klemm Wrote: [ -> ]
Usually, you won't need a post# for anything. Just use the link at the # top right to refer e.g. to
this post. Or use <Quote>, delete almost everything, and the reader can still click on the little right green arrow. Want more?
d:-)
(06-09-2014 05:23 PM)J-F Garnier Wrote: [ -> ]Nice mystery to solve.
I was curious and entered your program in the Emu42 emulator and ran it using either ROM A and C. In this way, I was sure to have exactly the same operating conditions. No significant difference. What you are observing is not caused by the software version.
One question: in you first post, you reported that a program of yours was running slower on
version A than on version C (+20% running time). Then you reported than your posted program POBR was slower on
version C than on version A (now +40% running time). Is that correct?
J-F
(06-09-2014 07:45 PM)J-F Garnier Wrote: [ -> ] (06-09-2014 05:23 PM)J-F Garnier Wrote: [ -> ]Nice mystery to solve.
One question: in you first post, you reported that a program of yours was running slower on version A than on version C (+20% running time). Then you reported than your posted program POBR was slower on version C than on version A (now +40% running time). Is that correct?
J-F
Very sorry my first post is botched - version A was faster & consistently so. A took 200s & C 280s.
I can hardly believe that I wrote that original error.
(06-09-2014 06:42 PM)Bill (Smithville NJ) Wrote: [ -> ] (06-09-2014 04:55 PM)Gerald H Wrote: [ -> ]If you could enter the progs under post # 13 & time them? It's a lot to ask so no offence if you shouldn't bother.
I do the following:
enter "seed"
Bill
I have checked against the programmes as stored in my HP 42S & the coding is identical - my calculators produce correct factorizations.
I believe post # 36 indicates that the posted programmes are written correctly.
Please check your coding again, as errors do occur - see my previous post & the initial posting on this matter.
(06-10-2014 05:23 AM)Gerald H Wrote: [ -> ]Very sorry my first post is botched - version A was faster & consistently so. A took 200s & C 280s.
Thanks for the confirmation.
And the running time difference is not +20% as I wrote but +40%.
(06-10-2014 05:37 AM)Gerald H Wrote: [ -> ]I have checked against the programmes as stored in my HP 42S & the coding is identical - my calculators produce correct factorizations.
Gerald,
For the sake of completeness, I run your programs on my physical A and C machines.
I got:
version A machine: 414s
version C machine: 432s
consistent with the observation that version A is slightly faster (+5%).
I assume that there is something different in the implementation of your programs in your C machine.
Can you please check again? - Errors do occur :-)
Only you can do it since you are the only one to get such a speed difference (40%).
Please share your findings, I'm now curious...
J-F
